Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: am i incorrectly seeing knock? 2015 SC f-150
    Jun 2008
    Tyler/Longview, TX area
    746
    Quote Originally Posted by LastPlace View Post
    ^^^ funny how all the fails knock goes away with e85.
    I ran tested 87% Ethanol with stock Roush spark tables and got knock. It's a real thing with the Roush blower.
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Quote Originally Posted by txcharlie View Post
    Definitely, and you tested it correctly to determine and rule out without damaging the engine.
    Mar 2018
    19
    Hi guys,
    I was reading about this issue because I think I'm in a similar position.
    My car (Whipple SC in a 16' Mustang GT) was making 780WHP with only E20 and nothing of knock. Now, I stroked it to 5.4L and add a +20% balancer with a 3'' SC pulley.
    First, I reduced 10 degrees just to be sure for the borderline table and I?m using E85 but still car is pulling 10 degrees and was making like 550WHP, I limit the knock retard to 5 degrees, and it gets to 650WHP with 10 degrees of timing I think is too low.
    Because of my new pistons and crankshaft, I know knock sensitivity changed so I removed 20% of all KNOCK SENSOR GAIN which says, ?This defines the sensitivity of the knock sensor, higher values are more sensitive.? But nothing changed. I don?t think there is detonation with 10 degrees and E85, specially because I?m 7800 feet over sea level so compression inside cylinder is lower.
    What do you guys think?
    Jun 2020
    822
    dperformance are you running global or per cyl retard? If per cyl, I would suggest logging the kr for all 8 at a high data rate and few other pid?s to see what each cylinder is doing.
