Fuel rail pressure 1600 psi at idle. new offsore high pressure rail sensor about 5 weeks ago.Started running the corn juice around this time had added flex sensor ,an the e92 was already set up with proper tables for it.Dont smell fuel in oil.Not Sure if iam have a faulty sensor or pump.Heres log gets warm if iam not gassing her up,running seperate wideband and its not far from stioch.Iam wanting to believe sensor an not the pump.I also blocked off vacum at intake to lower valley cover just see if it was puicking up crankcase fumes.Nope they still climbed to neg. 35 both banks.
