Results 1 to 6 of 6
Thread: 2015 Mustang Ghost Cam Issue
    Aug 2020
    Knoxville, TN
    91
    So I followed @GapRider's instructions on how to create a ghost cam tune in #182 over at this thread: https://forum.hptuners.com/showthrea...ford+ghost+cam. However, I have a slight drivability issue with mine. While in neutral at a stop, if I push my clutch in or let off the clutch, the RPMs briefly dip down into the 500s. Feels like the car is about to stall. Aside from that, I have it chopping really nice. I just want to fix this small drivability issue for stop-and-go traffic. Anyone else encounter this before and have a fix for it? Here's my tune as it sits phase2 pops + ghost cam.hpt
    Nov 2009
    All Around
    3,149
    a log would be good, torque reserve would also be adjusted for a more stable idle
    must also follow the VCT mode
    Aug 2020
    Knoxville, TN
    91
    Quote Originally Posted by SultanHassanMasTuning View Post
    Sorry. I should have posted a log. I attached one here. You can see it dip a little bit when I push the clutch in. Then, when I let out of the clutch, it really dips. I did it a few times so that you can see it reproduce the issue. The whole time, I'm in neutral. It's an issue when I depress the clutch to put the car into 1st gear to take off from a stop or when I am just nudging up in traffic and I go back to neutral and let off the clutch. Once it catches itself, it starts chopping again and idles fine. It's just those brief dips that are super annoying.
    12-2-21 ghost cam idle issue.hpl
    Aug 2020
    Knoxville, TN
    91
    I upped the torque reserve as you suggested, and it seems to have helped. I also lowered the correction window from 41 max and -41 min to 21 max and -21 min. It seems to "search" less now. Is there anything else I should adjust? Thanks!
    May 2023
    21
    Any updates with this thread ?
    Also could you please share the sound of it and the other adjustments you made to the torque reserve?
    Aug 2020
    Knoxville, TN
    91
    Quote Originally Posted by Dramex72 View Post
    I actually ended up doing a video on this for my YouTube channel:
    https://www.youtube.com/watch?v=xqWFb1pcHwk
