Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: MPVI2 (and 2+) prolink and AEM CAN bus
    Mar 2020
    Western Canada
    91
    Can’t wait for this to work!
    Sep 2021
    5
    Old thread bump. Is anyone else still having this issue? I have a 30-0300 flashed gauge with a mpvi2+ with pro features/prolink wired to the canbus correctly. I'm not sure it detects it when polling for additional parameters, but it will not log in the scanner. Running the latest Beta version.
    8,087
    Quote Originally Posted by laibal View Post
    -0300 flashed to what? If it's flashed to the -0334 type firmware then it doesn't get wired to the Prolink's CAN, it goes to the vehicle's CAN. They are different flavors. The AEMnet CAN in the original -0300 firmware was the type that spoke the same language as the Prolink's CAN.
    Sep 2021
    5
    Apologies, I should have clarified. I had an -0334 type that dr.mike flashed back to -0300 for me as I wanted to be able to use with my pro link. However with the wires added and correctly connected to the pro link adding the channels and polling for parameters with it connected doesn't log any data.
    Sep 2022
    11
    has this been fixed? with the MVP3
  6. #26
    Aug 2022
    Has anyone gotten this to work properly yet as mine in vcm always reads a lambda of 1; the wideband I am using is the aem 30-0310.
  7. #27
    Jun 2018
    Victoria
    3
    Hi Keith,
    Would you have the the pinout diagram for the Prolink+?
    Cheers,
    Tim
  8. #28
    8,087
    Quote Originally Posted by Rowse View Post
    Hi Keith,
    Cheers,
    Tim
    https://www.hptuners.com/pub/Pro_Link_v1.pdf
  9. #29
    Dec 2006
    Pensacola, FL
    500
    Old thread but I'm having an issue with this myself. I have a AEM 30-0310 and I am trying to log/display AFR on my scanner using the MPVI3 with the ProLink+. I have connected the AEMNet CAN high wire (black/white) to the ProLink CAN high wire (orange) and the AEMnet CAN low wire (green/white) to the ProLink CAN low wire (yellow). I repolled the scanner, added the AEM X series UEGO WB EQ ratio 1 PID. However, when I start scanning, nothing populates in the scanner. Thoughts? TIA.
    I'm not sure if this matters, but my swap is an 84 C10 - 2017 GEN V L86/8L90 with a E92/T87 using a Speartech wiring harness an running a 2015 Corvette OS.
  10. #30
    Apr 2024
    6
    I'm having the same issue as well. It's not detecting the prolink as a obd controller. Tried the aem pid in the mpvi3 options and still not detecting on scanner. Are you able to see the analog signal?
  11. #31
    Dec 2006
    Pensacola, FL
    500
    Quote Originally Posted by D_park View Post
    The analog signal works great.
  12. #32
    Dec 2006
    Pensacola, FL
    500
    Any luck?
  13. #33
    Dec 2006
    Pensacola, FL
    500
    Keith - has this been fixed? I added the AEM PID but nothing is showing up when I try to log.
    Quote Originally Posted by Keith@HPTuners View Post
    Ok, I've been told this is a bug in the current release firmware on the MPVI2+.
    We hope to have the fix in the public firmware, later next week.
    If you would like access to this firmware early, please email support regarding this bug and we can get you access.
    Thanks.
  14. #34
    Jun 2024
    3
    Quote Originally Posted by HartRod View Post
    HartRod I have been having the same exact issue. Created an account just to comment on this. Submitted a ticket on it #432677 lol
    I have an 03 C5Z with the AEM 30-0300, MPVI3, Prolink+, etc etc same hardware as you
    Same outcome aswell. Canbus wires connected correctly, but when I go to start a scan in vcmscanner it doesn't populate any information on the channel
    Hopefully we hear back something soon this is disappointing. If you find a solution please let me know, and if I do I will let you know.
  15. #35
    Tuner in Training Jabercrombie's Avatar
    Dec 2018
    27
    No can bus logging of AFR's
    Quote Originally Posted by brandn View Post
    Hopefully we hear back something soon this is disappointing. If you find a solution please let me know, and if I do I will let you know. Seems this one is definitely software bug related with vcmscanner
  16. #36
    Dec 2006
    Pensacola, FL
    500
    Brandn - I added a 120 OHM resistor in parallel with the CANBUS connections on the ProLink+, used the AEM WB #1 PID, repolled and now it is logging the AFR correctly. Hopefully this helps.
  17. #37
    Jun 2024
    3
    Oh man that's great news HartRod. Out of curiosity, what 120 OHM resistor did you use? I'd love to just copy your setup so I don't have to do it twice lol
  18. #38
    Dec 2006
    Pensacola, FL
    500
    I just ordered some off of Amazon. PM me your address and I can mail you a couple.
  19. #39
    Jun 2024
    3
    Man you're awesome brother. PM'd
