I have a customer with a cammed trans am. We were suppose to swap the heads and do a retune. First pull on the dyno and the car is going very rich. The commanded afr is set at 12.95 but it never sits there. As soon as we enter power enrichment it jumps to 12.4-12.6 and then plummets from there. It'll go as low as 9.8 before bouncing back up some. The car runs fine normally and the afr sits at a flat 14.63 while cruising.
Catalyst protection is disabled, I even zeroed out the tables just in case.
I zeroed out the eq ratio subtractor
Any ideas?
