Results 1 to 10 of 10
Thread: Demon trans tune in a Trackhawk
    Mar 2009
    S. Florida
    584
    Is it a straight copy and paste over or will the difference in gear ratios screw things up?
    Mar 2009
    S. Florida
    584
    I think the trackhawk is an 8HP95, is it not?
    Yes. I figure that was how beefed up trans was, but don't know. Why I'm on here asking, don't want to screw things up.
    Mar 2009
    S. Florida
    584
    This demon trans tune gonna work or wreck?
    the setting is based on the output shaft sensor and not on the wheels. therefore, the main pairs of gearboxes do not participate here as in NAG1
    Mar 2009
    S. Florida
    584
    Quote Originally Posted by 88nec View Post
    Please expand. I have a 2018 Trackhawk. Don't like the way Track mode shifts, falls flat, pops, then shifts. Thinking that has something to do with SC belt snapping. SC wound up, eng flat lines, SC free wheeling, eng engages, jerks belt, snap. Had it happen with a little light to light with a X5.
    Quote Originally Posted by coanan View Post
    a whistling sound would be heard if the belt slipped. If the compressor roller slips, then this can be seen from the inlet pressure. Is there a log where you can see the problem?
    Mar 2009
    S. Florida
    584
    I'm over exaggerating the fall on it's face. More like the computer torque management cutting spark/timing for the shift, it's just way over the top.
    I'm looking for a seamless steady pull between shift.
    It's not belt slip. The belt is literally ripped apart.
    My guess is the stalling of the eng during spark/timing cut.
    Clutched SC pulley free wheeling as eng power is cut, then power hits and grabs the SC pulley.
    That pulley operates on a sprag like the transmissions use. Grabs in one direction. free wheels in the other.
    Are all the pulleys native? I ran into a problem, the profile of the stream was too sharp. On 6.2, the belt goes green after all, reinforced.
    Does the pulley clutch work exactly? Bearings in the compress not wedge?
    Jun 2022
    Did you try it? results if you did
    Mar 2009
    S. Florida
    584
    Quote Originally Posted by MonstarSRT View Post
    Nope. Had Curt Dusterhoff tune trans, worth the price of admission. Now working thru the flex fuel tune.
