Results 1 to 7 of 7
Thread: New to tuning. Hard start. trying to tune Idle
    Jan 2022
    4
    Hi new to Tuning and I have a couple questions. first when trying to start cold it cranks and backfires i stop cranking and go back to cranking and it fires right up. I read a few post where it was the Cam sensor. I put a new one in and still same issue. I checked the wiring. I have 12 going to the Cam sensor with the key on. I have been following Rinkrat456 idle guide. it idles decent, surges a little up to I cut in the LTFM after doing the Idle airflow. then it runs a little rough. can someone take a look at my tune and see if there is something they see and point me in the right direction.
    2003 Chevy 2500hd 4x4
    6.0l w. NV4500
    cold air intake
    shorty headers
    Cam is a BTR Truck Torque cam
    thanks
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    307
    Do you have any codes? It is does sound like a missing cam sync, the car will start 50% of the time as it takes a stab, it's like the distributor being 180 degrees out.
    Can you log these?
    Jun 2009
    Melbourne Australia
    307
    Idle spark and fuel trims look fine, you need to add more logging channels, see what is available in the scanner in engine idle section and add away.
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    954
    Are you Drive by Wire or Drive by Cable?
    Mar 2011
    Ripley, MS
    1,864
    Quote Originally Posted by dhoagland View Post
    It's DBW.
    Jan 2022
    4
    It ended up being a bad cam sensor. I got kicked and got 2 vad ones from the parts store. I put the old one in from before rebuild and starting problem went away.
    Jun 2009
    Melbourne Australia
    307
    Quote Originally Posted by 03ChevyCrewCab View Post
    Yep, so many cheap poor quality parts on the market these days, pay the extra get Delphi.
