Anyone know how to burble tune a 15-17 mustang? The 18+ have a bunch of burble specific settings in the DFCO section. For 15-17, would you just directly edit the Torque Ratio clips in decel regions?
I attached it. It's just the factory Roush phase 2 tune.
phase2.hpt
If you have time will you do mine too?
Roush727-Return-ID1000-Final1.hpt
Ill pm it back to each of you with in the hour just compare the files and see what was changed, ok?
I never heard back from stephen but I found that lowering the Torque Ratio Clips under decel load increased the burble intensity. These are the Lower (Long) [ECM] 44894 and Lower (Short) [ECM] 44895 tables. However, I cannot figure how to lengthen the duration of the burbles without disabling DFSO entirely. I do not wish to do this because I do not want it to burble the entire time I'm off the gas. I just want it to burble for 2-3 seconds instead of 1 second or less when I get off the gas. Is there a way to increase this duration so that the car transitions into fuel cut slower?
you will need to adjust your ignition adv
Remote Tuning [email protected]
Bumping this thread. Still haven't figured it out.
Made some small progress. If I increase the ramp on rate to 50 and lower the spark torque reduction setting for DFSO to 0.050, I get some pops before DFSO enables. It's still weird that you can't control the DFSO entry time though.
You can there's a scalar for it.
The time delay. You may not have access to it.
decipha @ EFIDynoTuning
http://www.efidynotuning.com/
