Want to fit 4 bar map for boost with hpt any help would appreciate I?m in the uk
orig 370 with vin.hpt
thank you for having a look new to hpt allways used kess and k tag swiftek like the look of hpt thought give it try for this project cheers
Are you sure this has a MAP sensor? Nissan went away from having a MAP sensor in Y62 Patrol, its MAF, they use tables to estimate MAP based on injector Pulse and intake manifold pressure. This looks the same. It may have a baro sensor.
