Results 1 to 15 of 15
Thread: 65/66RFE Tuning
    Banned
    Jan 2018
    Everywhere
    1,772
    65/66RFE Tuning
    The 2010+ 68RFE tuning I do, very well developed tuning, has been used on a couple 65RFE transmissions now with seemingly pretty positive results. I?m open to 65/66RFE tuning for anyone interested in it.
    Banned
    Jan 2018
    Everywhere
    1,772
    If NOV87 sees this, maybe he can report back his impressions on the tuning here.
    Jun 2021
    6
    So, I have 2014 RAM1500 with 65RFE. As know the way that transmission operates is nothing to be impressed by. I have been looking to fix that one way or the other, so started a conversation with Jim P and he agreed to take a look at the tune and see what he could do to help. The reason I went with him is his knowledge and experience with the RFEs. I have tried playing with settings myself but stopped due to lack of experience with tuning. With Jim's tune, I do have firm shifts, no more hunting for gears whether upshifting or downshifting. Always in the right gear. TC locks early.The long drawn 2 - 4 shift is completely eliminated with enabling of 3rd gear. The shift schedule is a lot different know. Overall the truck is a pleasure to drive and the tranny operates great. My opinion, that's how it should come from factory. I highly recommend that, wish I had it done it sooner.
    Sep 2021
    Jim P pm sent
    Aug 2020
    11
    545rfe ngc3/ngc4 tuning?
    Feb 2022
    19
    i am very interested in what can be done with WOT lockup on a 545rfe/65rfe. i cant seem to get mine working
    Oct 2021
    7
    wot lock up and
    Quote Originally Posted by Jim P View Post
    Hello Jim p. Sorry if this is in the wrong place for inquiries. I'm seeking help on 2 things and you and Chrysler, seem to be the only one with the answer. Chrysler don't talk much. lol. How in the world to do you stay locked tc at full throttle? And ecm 10201 in hp, min threshold for tcc, ecm 10202 tcc shaft speed. sit at 6k on the 65 and 66 but on 68, Its sit to 1250 and 1200. I'm fixing to try the 1250 and 1200 from the 68. will it break? Thanks in advance.
    Feb 2022
    19
    I got it working. i just had to add some tables for WOT to the torque converter TPS % column.
    it does seem like there is still something not allowing lockup until the slip is under a certain threshold
    Dec 2021
    Middle GA
    13
    I am interested. 65RFE with 2700 stall. Just need a base trans tune so I don't burn converter up.
    very interested. ive been doing some self tuning with great improvements, but its just not perfect yet, would appreciate the help or looking at my file.
    Nov 2022
    Alberta, Canada
    8
    I'm new to tuning the later gen, I've got my 08 working flawlessly. When tuning this generation, with the mds shut off, is there need anymore for the partial lockup, my 08 never uses partial lu? When turning on the 2-3 shift, do you then need to change the shift schedule for the 4-5 and 5-6? My trans shop just finished a 12 ram 1500 and I am in the process of getting the shift strategy to where it should be. Can you tell me which tables use turbine rpm and which ones use output shaft? Help would be appreciated. Thanks.
    Mar 2023
    Hello Jim, I just had my 65rfe rebuilt. It still has the slow shifting and shifts 2nd to 4th. I'd like it to be more punchier shifts and to actually shift into 3rd. Something like what NOV87 mentions.
    How do I get in contact with you? I know nothing about updating tunes either.
    2012 ram 1500 5.7 2wd
    145000 miles all stock.
    Apr 2023
    Sofia, Bulgaria
    36
    PM Sent yesterday. Mine is 545RFE on Jeep WK.
    Sep 2024
    Hi Jim P I am hoping you can help me with turning off the tcc lock up on low gears on a 66rfe.
    Sep 2023
    438
    Not sure why you’d want it turned “off”, will generate more heat from slip but just raise the thresholds in the lockup tables and the minimum thresholds to the max you can put them.
