first off it's the same 97 turbo s10 i am working on. heres a couple of problems o am running into. i cannot reset my fuel trims, i do not have the buttons in my scanner that allow it to, guess that feature was not added yet
so with that being the case
1. How do i reset the trims? do they take x amount of time or miles? if so how much? it seems when i get things close in my ve the slowly keep changing. i tune buy cut and paste, log then scan. is the trims not changing as fast as i flash them hence they change over time?
2. when do i use the paste special multiply% vs. using the multiply%-half? is one better then the other?
3. i will post my tune and scan but i cannot seem to get it dialed in, like it will be close to 0 and i cut and multiply from my histo onto my editor, hand smooth and flash, it will go from being say -2 rich to 2 lean? how is that, the only guess i have it i am flashing and giving the computer enough time to learn the new flash.
4. i do not have a ol ve chart so i am logging in closed loop, egr removed"physically" DFCO off, 12.5 PE AFR multi 1.0, and i am having to use 30 ve offset to get my afr down. i have my histo set up so i can cut and paste my low rpm ltft's and my 50% PE wideband error, i take both these and paste them on my low single and double table, used the high ltft and wb error for the high table. is this wrong? i get close then then it starts going further away again. like i said my PE is at 0 delay and 50.% throttle.
5. i have my kr still to deal with but i am having a heck of a time getting my ve figured out. i am sure i am missing something...
currently i have the offset 30% tune in the truck and i am chasing trims all over along with AFR in PE........please help
