Results 1 to 16 of 16
Thread: MAF Adaptation
    Apr 2013
    Buffalo NY
    93
    MAF Adaptation
    How many of you leave MAF adaptation turned off when you get your MAFs dialed in?
    Right now I have LTFTs disabled and MAF adaptation. Running around 1-3% stfts. Thinking about just leaving it turned off.
    2019 Ford Raptor Tow Rig Scarab 195 Open 250HO
    2008 Shelby GT500 VMP Gen II-R (17psi), JLT 123mm CAI, Ford SCJ Monoblade Throttle Body, 56# Injectors, BoostAPumps, VMP triple pass heat exchanger (dual fan), 170* thermostat, BBK long tube headers, Dual resonators, Magnaflow Catback, LC2 Wideband, RXT clutch
    Dec 2019
    11
    I'm just going to bump this thread as I'm curious on this. Is Maf adaptation allowing the use of the STFT or LTFT? Right now I have it disabled.
    Oct 2016
    Poland
    1,773
    Turn temp compensation off as well.
    Mar 2010
    New Orleans, LA
    630
    maf adaption applies half of the kam error to load correction.
    The logic is that if the maf is off its not just fueling that needs corrected but airflow as well. Kams are a multiplier after airflow (load) is calculated. Maf adaption allows half that kam error to be applied to airflow so load is corrected too.
    as long as you dial your tune in properly its not going to make any difference one way or the other
    decipha @ EFIDynoTuning
    http://www.efidynotuning.com/
    Dec 2019
    11
    Does that apply to all driving conditions i.e. cruising and WOT? On the dyno it hit the target AFR with the current maf values.
    I should also mention I have LTFT turned off.
    Mar 2010
    New Orleans, LA
    630
    if kams are disabled then maf adaption cant function
    Dec 2019
    11
    Ok thanks for clearing that up. I've actually been trying to pick through your writeups for info on the 2005+ mustangs. Now that i've tuned one I'm re-reading a lot of information and it's becoming clearly. Much different than a GM.
    May 2018
    Germany
    590
    I activate the anticipation again after tune. The transient table seems to be dead, so there is always a lean spike during accel on afr meter.
    Mar 2010
    New Orleans, LA
    630
    anticipation has nothing to do with adaptation
    if yu have inferred load dialed in and get a lean spike on quick throttle stabs you need to reduce the manifold volume scalar
    Senior Tuner CCS86's Avatar
    Austin
    1,089
    Quote Originally Posted by decipha View Post
    You are sure that it takes affect on LTFTs, but not STFTs?
    Mar 2010
    New Orleans, LA
    630
    yeah
    May 2018
    Germany
    590
    did the anticipation correct / help maf to get faster ?
    Hi I'm new to forums & tuning. I have been studying this as well. IMHO, MAF Adaption could be of some benefit during low-speed RPM operations during CL where the PCM will also be performing EVAP operations where the LTFT's will be affected thru STFT's picking up the unmetered air entry during purge cycles, thus by MAF Adaption enabled taking 1\2 of the avg LTFT's & applying it thru the MAF multi to the load% calcs (TQ\VE) should improve low speed TQ output during accel vs MAF Adaption disabled. Yes, the amounts will usually be small if all else is sound but IMHO any extra lb\ft of TQ gain is a benefit thus kinda validates enabling it.
    Or am I just being a noob here & am overthinking this?
    Any info given is appreciated!
    Feb 2012
    TEXAS
    639
    Quote Originally Posted by GlassRoofStang View Post
    2015+ all run closed loop except for cold starting. Turn adaption forces open loop which shuts off any adjust the computer can make in general, and allow the calibrator to use STFT to get the MAF transfer within the 3-5% for part throttle tuning. Once Part throttle tuning is complete you can turn adaption back on and dial in WOT. Since 2015+ come with Widebands from the factory you can use LTFT plus STFT together and make adjustments to MAF transfer function. ever turner has a method to how they want to tune. if you research the How to logs there is a great references.
    Mar 2010
    New Orleans, LA
    630
    adaptives can't update while evap is purging
    yeah big time over thinking it
    Quote Originally Posted by mstang_man View Post
    Forgot to mention that I'm working w\ a Spanish Oaks PCM for 05-10 S197 so my bad.
