could someone look over this tune?
again as always thanks in advance. it a 97 2.2 4 banger s10 t3 turbo, cartech fmu non intercooled. here is my last log and tune. i am still having trouble and i and could use some help here, ve and timing, also where to set pe as far as throttle position, please look it over...again i'll owe ya a drink anytime thanks
what size injectors?? Why are you still running the FMU?? What is your fuel psi?? How much boost are you running??? Do you have a wideband??? I cant view your file, I may need to update but I dont have time to right now.... I hope your not running the dogpiss out of it non intercooled....
P&P Tuning
dude you must be kidding with those ve changes. they are the most eratic things ive ever seen. especially without an intercooler you are trying to mess something up. smooth them ve tables at a minimum and try again.
2006 SS Cobalt SC
Stage 2 ZZP Cams
Headers, 3.0" Full ZZP Exhaust
60lb inj. Intake.
2.8 Pulley
72# Lb. Supertech Springs
LNF Ext Valves and lashers
Cobre H/E, option B.
Torque Damper
HPTuned.
Bitchin'.
