Results 1 to 9 of 9
Thread: 5.7 w/ HRT stage 1 comp cam
    Mar 2022
    4
    Got this kit for my truck
    https://www.compcams.com/nsr-stage-1...-2009-cpg.html
    Have it installed 2011 Ram 1500 5.7
    Did MDS disable under engine-fuel saving
    Truck doesn't want to idle worth shit.
    Does anyone have a base tune or a hint on how to get this running better?
    Tuner in Training GaS Engines's Avatar
    Jan 2021
    48
    May need to raise Idle RPM set points, remove negative timing on the Part Throttle tables and smooth, adjust TB airflow model. Turn NN off, and use VE tables.
    2013 Charger R/T - 1-3/4'' Longtubes, Catless Mids, 180 T-Stat, CAI, 6.4 Manifold Swap, 370whp@5600/411wtq@3950
    Contact [email protected] for Engine Building or Tuning needs!
    in the idle tab try putting all of the values in your intergral max table to 25.
    Mar 2022
    4
    Quote Originally Posted by GaS Engines View Post
    Do you have a file I can compare with? I'm just learning about the NN now and what it does
    Mar 2022
    4
    If someone can, check my file
    Jan 2021
    48
    Quote Originally Posted by rcautologic View Post
    Try this.
    Robbins 2011 Ram RT.hpt
    May 2025
    Te funciono pudiste arreglar el problema
    Jun 2025
    hi i have a 2010 charger with the same cam setup I'm trying to get it to drive without stalling can anyone help I'm a novice at tuning so if anyone could help that would be great
    Tuner fumanchu182's Avatar
    Oct 2019
    Maryland
    92
    Drop your current read and a log of the tune when it stalls.
