Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Thread: 2016 mustang gt new too tuning
    Feb 2022
    22
    I cant get it still wont read the e85
    Feb 2022
    22
    if someone could fix this tune I would pay for your time
    Feb 2022
    22
    I got it to run using settings from 2017 f150
    Feb 2012
    TEXAS
    644
    https://www.dropbox.com/sh/97e689wv0...nwWK71KVa?dl=0
    I will leave this up for 24hrs. this is some of the parameters your were missing on your flex file.
    Feb 2022
    22
    how do I open it with hp turners or view it nothing I got on my computer will open it
  6. #26
    Feb 2012
    TEXAS
    644
    in editor click on Edit> TEMPLATE APPLICATOR> Open File>Apply Changes > a box OPENS with a Green Arrow it>click it and it will apply the file
  7. #27
    Feb 2022
    22
    Thanks I will check it out
  8. #28
    i used frpp3 as the base file for my 2016 gt with 350 tb,manifold headers with e85 .
  9. #29
    Feb 2022
    22
    where do I get that at
  10. #30
    Feb 2022
    22
    Quote Originally Posted by GSLSE20B View Post
  11. #31
    Feb 2022
    22
    this is my log with the gt350tb installed still got some tq based decal coming on wot
  12. #32
    Dec 2017
    767
    Should be a copy in tune repository
  13. #33
    Feb 2022
    22
    what do you think about this wot logs is torque control supposed to take over spark source
  14. #34
    Feb 2012
    TEXAS
    644
    Quote Originally Posted by Smokinrob View Post
    Change the under flex fuel tab> GENERAL > NVM AFR RECOVERY > to Use Initial Value (this should help read for E-85)
    Also MAF Peroid Still needs work, from looking at the 4th gear 5,000 rpm log file. Fix the Fuel trims
    IPC Torque Monitors >raise wheel torque error say 75,000.00 ( helps with torque monitoring )
    Max Torque Raise to 650
