any one knows were can i ifind a list of what TYPE means or does cause i can find nothing about this
all the way from Tampico bay Mexico
HP tuners can you answer this? I'd like to know what all these mean as well.......
Bump this up. I'm curious as well.
As a matter of fact, so am I.
Bump again.
Anyone?
Dang! Must of stumped the forum.
I'm guessing this is how you rate them 1 being the worst and 9 being the best lol! but for real couldn't hp tuners answer This?
Maybe, I guess.
I'm not sure if this is relevant in the HP Tuners format or not, but this is from another user posted in a different thread:
Typically, Ford DTC's are as follows:
0 = Disabled
1 = No MIL
2 = 2-trip MIL
3 = Instant MIL
5 = 1-trip MIL
6 = Selectable 1 or 2-trip MIL
I've noticed that setting many of the tricore and newer dtcs to zero doesn't give you the desired result. It would be nice to know what 7,8, and 9 represent.
i think it might be the severity of the code im not sure all the important data like fuel pressure and engine over speed are at high class types possible telling the ecm to shut the truck off in these conditions and for less severe the types are like 3 which maybe means reduced power or limp and 2 and lower just look like normal sensors
I'm not sure don't quote me on his but like i said it does seem as if the higher the severity the higher the class and as far as hpt that may be why they arent anwsering the question ya know cause those codes may be used to change some stuff that we are not allowed to change but im not sure im just stating im quite possibly wrong lol
1996 5.7 vortec k1500 (4x4) 411 pcm swap ,lt4/lt1 hot cam ,1.6 rockers, mpfi upgrade, cai, long tube headers ,true dual exhaust getting ready for the turbo
lmk if you need help with your 96-99 vortec just text my number
email :[email protected]
(956)784-1824
i know this thread is old but im stll wondering the same some codes keep making the same even if you disable them like p060A if the pcm triggers it shows the REDUCED POWER warning even if is disble WTF??
i know im passing some flow limit or soemthing like that but i canf find the reason to adjust it
