![Quote](images/misc/quote_icon.png)
Originally Posted by
conmano
Thanks for your reply, and input, much appreciated. Nice to know i am not the only person trying to tunes F-types with HP tuners.
I finally got around to finishing the upgrades, and tune. I installed the VAP pulleys, both upper and lower, fairly easy installation especially if you use the new GripTech upper pulley, as the hub can be heated and slipped onto the supercharger snout. Other modifications included a full custom 2.5 inch twin exhaust with 100 cell cats and K&N air filters.
I decided to tune the car on a good quality fuel 98 RON (entry level race fuel). It?s not a daily, so I would rather run a good quality fuel that helps prevent any detonation and also helps keep the valves and injectors clean given its a DI engine.
The main area of the tune I concentrated was the driver demand tables, boost max and limits, Desired load, Max load, Throttle body airflow, Airflow Desired and Model given the increase in supercharger RPM, fueling and timing, with some minor adjustments to the Maf meters based on short trims errors. The max power was achieved with a fuel ratio of 11.8 and timing approx. 27. The DI engines can run slightly leaner due to their efficiency put I didn?t want to push my luck much past 12.0 for obvious reasons. Average boost was 12.5 psi during the run. This part I am not 100% sure a got all the potential out of the two pulleys. The pulleys state they are good for 14.5 psi, however as we know boost is a measure of back pressure so maybe the exhaust is flowing better and boost is down a little!!
All my runs were done in 5th gear. At that stage I was only revving the engine to 6000rpm as the transmission was limiting it.
At 6000 rpm in 5th, it was putting down just over 600HP at the wheels. I can comfortably say if I saw another 800rpm, it would have hit 620HP easily. That?s without playing with the cam timing yet. I am not one of those guys who tries to estimate the flywheel HP as who knows how much is lost through the drive line.
Overall, the car is a total weapon on the street, and if not respected it will send you heading towards the curb in a flash LOL. Time for some better-quality tires.
