Results 1 to 7 of 7
Thread: Uncle! Supercharged 2018 Charger Lean at WOT
    Mar 2010
    Belton, Missouri
    92
    I am reluctant to post this problem, because I know it will be something stupid, but here goes. The car was originally a 5.7 but has been stroked to 431 c.i. and now has a supercharger added. It has FIC 1200 injectors. The car goes lean when transitioning to WOT, and I haven't been able to make any adjustments to solve the problem. I have raised the VE table in the WOT regions and it did not respond. I raised it to silly levels and it still shows lean. It commands the PE early and even goes rich for a second, but quickly goes lean and I lift. I started with the FA inc rate at .0006 and worked up to a max of .5 with the same results. The injector pulsewidth stays around 6.6 and doesn't increase above that. At this point, the boost is very low ( 3 psi) and the fuel pressure shows good (maybe dropping 3 psi or so to 55 Psi). The injector duty cycle is very low. I feel like the computer is limiting any adjustments. Any help would be greatly appreciated. I have attached a sample log and tune file.
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    197
    This should solve your problems
    Western New York's Performance Headquarters
    716.830.0506
    Mar 2021
    Pompano Beach FL
    272
    Adjusted your PE Rate Try it. Let me know. Keep an eye on A/F
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Mar 2010
    Belton, Missouri
    92
    Quote Originally Posted by JnJSpdShop View Post
    Thanks so much. I appreciate it. I'm betting this is it.
    Mar 2010
    Belton, Missouri
    92
    Quote Originally Posted by N2speed View Post
    Thank you. I will check it out.
    Feb 2019
    Owensboro, KY
    266
    How did this turn out for you? I having similar issue with lean transition into wot. Causing knock. Tried the same steps to correct as you did with no help.
    Mar 2010
    Belton, Missouri
    92
    The solution provided by JnJSpdShop was the problem. I had changed everything for boost, but failed to update the Max Map limit. I went ahead and bumped the FA inc value up to .001 just to get the fueling to come in faster also. I had already maxed that out before and it wasn't the core problem. Good luck.
