Results 1 to 20 of 22
Thread: 2015 6.7L Powerstroke, EGR and DSP Delete, cutting power above 2500 RPM
    Aug 2021
    7
    I.ve deleted EGR and DSP for a Off Road Truck, I have the EGR table "0" and all Diag related on "Disable". didnt change anything else until I learn Diesel tuning, witch is my first, so my goal its make a little more power but not crazy, just safe so I can use the truck to pull a trailer with a race car inside on weekends.
    The truck drives good in low rpm, if you kick the gas it goes strong and quick on 1st gear, then it shifts and get lazy above 2500RPM like no turbo pressure...before the delete was fine. after the Delete, pop up the message "Engine Power Reduction" and with the EGR data tuned it didnt came up anymore, BUT still lack of power above 2500 RPM...Where to start tuning now?
    PM me.
    Aug 2021
    7
    Sorry your contact is not working, please message to [email protected]
    Aug 2021
    7
    Quote Originally Posted by Toad0407 View Post
    PM me.
    please message me
    Banned
    Jan 2020
    Arlington WA
    250
    pm me if you need help
    Quote Originally Posted by AMERICAPARTS View Post
    please message me
    Emailed you.
    Apr 2020
    10
    Did you get this figured out? I just bought a 2011 6.7 and need some help along these same lines
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    479
    Quote Originally Posted by Markcuckerberg View Post
    PM me I can help
    Feb 2024
    2018 6.7L Powerstroke
    PM me.
    Having the same issue. Please message me where I can look to fix this problem.
    [email protected]
    (208)627-9633
    Mar 2017
    I'm having the same issue. Sent you a PM. Thank you.
    Jul 2019
    Florida
    110
    Just EGR?
    Mar 2024
    New to the tuning world and eager to learn. I'm trying to do an egr/def delete on a 2011 6.7 power stroke. mostly used for farm use, hauling fuel tanks and such around any chance someone has some files I could look at so I don't go into limp mode right out the gate?
    Aug 2023
    canada
    51
    Wont be able to with hptuners platform.
    Feb 2012
    TEXAS
    639
    it seems ford has some built in logic that cuts power around 50mph with egr removed. no other changes to calibration other than egr turned off. only code that comes up p2425. with diverter valve disconnected truck will do 20mphs no matter how much you push the pedal.
    Jun 2012
    warrenton va
    479
    There is no ?logic? that does that.. there is something in the tune that isn?t right.
    Literally 1000?s of trucks out there running perfect.
    Feb 2012
    TEXAS
    639
    Quote Originally Posted by mstang_man View Post
    SO what i am seeing is a boost issue, during acceleration i can get up to about 50mph, and boost does not a get above 10psi. I am not sure what i am missing.
    Aug 2023
    canada
    51
    is throttle valve disconnected?
    Feb 2012
    TEXAS
    639
    Yes, the throttle valve is disconnected. what i have applied i still receive to dtc P2456-00 & U059E. I would assume the file i applied would have turned that off. everything is as far as fuel and torque tables are all stock. TCM is also stock. I was thinking about doing an emission relearn using my scanner?? any help would be greatly appreciated.
    Aug 2023
    canada
    51
    egr has to be disabled in the xdf file. or else it will go to limp. just killing the code wont deactivate egr.
    Feb 2012
    TEXAS
    639
    Quote Originally Posted by dieselpitstop View Post
    I dont have any other files to compare to, some i am unsure of what i am missing.
