Results 1 to 20 of 32
Thread: CAN AM / HP Tuners: Injector Dynamics Calculator
    Oct 2007
    Crawfordville, FL
    2,583
    The good folks over at Injector Dynamics have just released a calculator to use when using their injectors in a CAN AM. Using it is pretty straight forward. Good data in = Good data out.
    Feel free to ask any questions.
    CAN AM / HP Tuners - Injector Dynamics Calculator
    Eric Brooks
    HP Tuners, LLC
    Jan 2022
    Galloway NJ
    182
    can this calculator work for SeaDoo?
    Oct 2007
    Crawfordville, FL
    2,583
    Quote Originally Posted by Tbranella View Post
    Yep.
    Eric Brooks
    HP Tuners, LLC
    Jan 2022
    Galloway NJ
    182
    but this is only for the ID injectors?
    for example, it is accurate for the Riva VT1100 injectors? (Bosch 1000 ev14)
    I'm looking for injector slope numbers for the Bosch 1000 ev14 injectors.. how is that HP Tuners injector slope number calculated?
    the Bosch data sheet doesn't have that HP Tuners injector slope number.
    Dec 2019
    Florida Miami
    15
    do you have a part numbers for the ID injectors we need to use?
    Jan 2022
    Galloway NJ
    182
    Quote Originally Posted by 3o5-CTS-V View Post
    it's probably the smallest injector listed on the calculator.
    Jul 2017
    529
    You'll size the injectors based on the hp you intend to produce, same as you do in a car.
    Jul 2017
    529
    I have one Outlander uses three ID2600cc injectors.
    Feb 2018
    7
    Question
    I need help scaling IDs 1050X on a 2019 Can-Am Maverick XDS.
    I used calculator values but maybe there is something missing or I am doing something wrong.
    Stock
    2019CanamMaverickXDS.hpt
    w/ calculator values
    2019CanamMaverickXDSMR1050X.hpt
    Jan 2022
    Galloway NJ
    182
    Quote Originally Posted by MRTuning View Post
    Stock
    Looks right to me, that's exactly all the data I entered for my SeaDoo GTX 300 for the same injectors.
    How is it running?
    Jun 2020
    6
    How is it running?
    Bump to this, this is correct. I am using the same.
    Oct 2022
    Any chance you have the one for the Polaris RS1
    Nov 2022
    I need some help. I tried to tune can am x3 turbo 2018 with id1300 injectors with external wasgate and 3 bar map sensor 201230280 . if anyone have a tune file please share it with me .
    Aug 2020
    4
    Nice video walk-thru video from Injector Dynamics to setup scaling (w/ explanation now has PW tables + breakpoints) using updated Wolfram calculator. https://www.youtube.com/watch?v=e7nAR70Bwh4
    The above link (beta) should be updated to point to https://www.wolframcloud.com/obj/inj...Data_Generator linked from Injector Dynamics website. e.g. http://injectordynamics.com/can-am-utv-products/
    Advanced Tuner RUTHLESS's Avatar
    Sep 2022
    WorldWide
    245
    Does anyone know the size / rating for the stock RXTX 325 injectors?
    Jan 2022
    Galloway NJ
    182
    Quote Originally Posted by whittlebeast View Post
    same injectors as the 300. they're no different.
    Sep 2022
    WorldWide
    245
    325 Is a 100lb injector that is very different from the 300 model .offset changed due to the 80psi of pressure vs 300 56 psi base
    Jan 2022
    Galloway NJ
    182
    Quote Originally Posted by RUTHLESS View Post
    same exact injector.. part numbers for the 300 (from 2016 to 2024) and 2024 325 are the same.
    and the technical presentation for the 325 doesn't mention a different injector.
    so, the same EXACT injector is used on the 300 and 325 from 2016 to present. don't believe me? look up the part numbers!
    Jan 2022
    Galloway NJ
    182
    "Ruthless"
    ^^^^^^^^^ doesn't know the 300 and 325 use the same injector!!!!! BWHAHAHAHA!
