Results 1 to 16 of 16
Thread: Tuning for cam
    May 2022
    14
    Tuning for cam
    So I know when adding a cam you need to decrease the VE in the lower RPMs and increase in the upper RPMs. I do have it sorted out in the upper range but some questions in the lower idle areas.
    Noticing the spark does bounce quite a bit and believe this is because the VE is not quite right yet but would like some input on this. Also, when rolling off the throttle it sometimes stalls. In the car world we would add IAC. Is there something I need to configure on this?
    Jul 2017
    529
    The spark bouncing at idle, is from idle control, idle moving at rpm is from spark efficiency/torque control
    May 2022
    14
    Quote Originally Posted by MRRPMBRP View Post
    What is the best way to fix?
    Jul 2017
    529
    Quote Originally Posted by Tom Dottavi View Post
    What are you wanting to fix?
    Banned
    Jan 2022
    Galloway NJ
    183
    I think he means fixing the spark bouncing at idle.
    Jul 2017
    529
    Quote Originally Posted by Tbranella View Post
    Spark moving around at idle is normal, as it is in about all efi electronic tb cars.
    May 2022
    14
    Completly agree with you. This is one of the ways it keeps the RPMs where it needs to be. Just seemed to be more than it should be. Got my VE dialed in and the KPA is now around 65-70 and the idle is much better and timing does not seem to jump around as much.
    Still have a small issue where if I let off the throttle, RPMs drop and sometimes it is not able to recover and stalls. In say a Ford, I would increase IAC.
    Jul 2017
    529
    Increase sc tq, or reserve tq, or both
    Tom,
    When you started, did you just add a percentage to the base VE in the higher RPM range, and pull some in the low? Say, 20% multiplier for the extra lift/duration at higher rpm and minus 5% for a stable enough idle to tune?
    I was looking for a safe baseline so it's not too lean while doing the actual data logging to dial in the VE...
    Advanced Tuner RUTHLESS's Avatar
    Sep 2022
    WorldWide
    245
    what cam are you using ?
    Ruthless,
    The way these were ranked in order of performance (dudes over on the FB group), which I take to mean the most aggressive duration/lift:
    OEM 230
    OEM 300
    OEM past year supercharged skis
    OEM 325
    Calas Performance
    I am going to go with the Calas and his springs/retainers. I know the easy way would be to use a 300 or even a 325 cam and then I'd have oem 300 tables to use as a starting point.
    Your cam gets good reviews on the FB group as well, by the way, I assume it's up there at the top!
    What are your thoughts on going in airflow/fuel?
    The issue with the 230 cam is anything is a significant improvement, want to be safe when I start the tuning process!
    Aug 2010
    Detroit, MI
    1,101
    I know I've said it before, but swampdonkey is the best forum handle ever.
    Sep 2022
    WorldWide
    245
    Quote Originally Posted by Swampdonkey View Post
    Ruthless,
    OEM 230
    OEM 300
    OEM 325
    Calas Performance
    YUP, my new cams are made by Kelford Cams, and we use beehive springs and titanium retainers also by Kelford Cams for the best acceleration in an sc build.
    the best part is our camshaft doesn't need special tunning to be stable in iddle like others with ibr error issues
    Its gonna have to be tuned once the mods start comin. Its nice that yours has a stable idle. Where does it fall in the line above in terms of torque across the curve?
    I wish the powersports would post specs and dyno charts like the car guys do.
    Thanks.
    Sep 2022
    WorldWide
    245
    Thanks.
    fueltech estimated power 690hp
