@HPTEngineers, it would be awesome if you guys could look into the NAG1 progamming logic and let us know why all of our JK transmissions have the shift delay/hanging issue in the 2-3 and 3-4 upshift when going uphill.
There a re a couple of companies out there, RPM Extreme and OST Dyno claiming they can cure the issue if we send them our TCM's.
for example from RPM Extreme website:
Product Description
This TCM upgrade is for 2012 and newer Jeep Wrangler JK with an automatic 5 speed transmission (WA580 - NAG1).
Its a know issue that if you run larger tires and gears or a supercharger the transmission just wont shift when its supposed to.
usually 3rd and 4th gear hang way too long and the dang thing downshifts at every slight hill causing you to rocket up at redline.
We have the fix. This custom programmed TCM will correct all your issues.
We rework the auto shift speeds and get it back in line with how it should be
We rework the wide open upshift tables to maximize performance at WOT
We turn Auto Stick on and rework the Auto stick downshift tables for a nice aggressive feel
Shift pressures are adjusted for a better feel
Torque converter apply and release tables are tailored to the new shift schedule
Torque limits are increased to allow the engine to provide a little more torque
Rpm limits are increased to keep you out of TCM limp mode
We offer this upgrade two ways.
SEND IN: Send us your stock TCM and we will flash it and send it back to you ready to go.
EXCHANGE: Purchase a flashed TCM from us. After you have it installed send us your original TCM and we will refund the CORE charge ($250) back to your credit card. ( core must be in good working condition and from your vehicle )
So If they can do it, we should too since we have access to the TCM
Come on guys, HPtuners is the leading tunning platform in the entire world, help us out here.
