My hard drive crashed so what did I loose and what to do next???
James
James
02SCSBZ71;(current mods)E-fans w/nelson harness,ASP crank & alt, Volant ramair w/k&n,UPD lid,Mac perf tube & elbow,Por & pol bbk 80mm TB/bypass,160 stat,Supermaxx header system,2 chamber dumped @ cab,MSD 8.5,NGK #6(indexed),Built 60E w/transgo/vette servo,Hughes deep/fined trans pan & SFI fp,Fuddle 3800 verter w/cooler,alum ds w/billet trans & pinion yokes,digital trans & oil temp, speedo in a 3-pillar pod,Eaton locker,T/A cover,Weld chyenne 6D's, BFG kdw's,Nelson 93 road tune.
Just re-install the software and re-sync your licenses per the popup you receive when you load vcm editor or vcm scanner for the first time.
thats it.
We got this guy Not Sure, ...
Will it use 3 more credits to relicense.......it came with 8?Originally Posted by Keith@HPTuners
James
the licenses are stored in your hardware dongle not your software
No....you can install it on more than one computerOriginally Posted by closet red neck
DH
2004 MSG A4
Appearance: Billet Plate&Sill/SS Insert/Screens/Blackout/Lowered/CCW SP500
Perfomance: 416 CI/228-232@114/AFR 225/FAST/LS2 TB/36#Injectors/Honker/RPM(IV)/Vig2400/Z06 Ti/Kooks/3.42 Gear/Hotchkis/Bilstein/Z06 Springs/Eradispeed/Hawk HP+/Trans Cooler/B&M Trans Pan/RonDavies with EOC/Nitto R2's/AMWcan/Rocker Rails/Frame Savers
Mods & Tune: A&A Corvette
??? RWHP / ??? RWTQ
1/4 mile: mid 11's ??
WSIR 1:37.68
Thank you very much gentlemen!!!
James
