What is the main difference between the 96-97 lt1 pcm and the 98-02 pcm of the f-body camaros that doesnt allow us to utilize HPT to tune the lt's? I had the same issue 5 years ago when i built my lt1 but i forgot what the issue was exactly. I had to pay for a mail order tune back then.
Working on swapped vehicle.
P01 from 99 Silverado.
Read and wrote fine. Did Speed Density OS. Wrote entire fine. Trying to do adjustments.
Getting x36 error.
Tried to use GM SDS flash to stock - can't even start a write.
Vehicle starts and runs. I can datalog and do RTT.
Just can't write.
P.S. I believe this happened to me long time ago before too. The SD was from a Camaro. Is F-Body OS corrupting truck PCM?
FYI grounding pin on the motherboard revived both PCMs.
https://www.customecm.com/gm-bricked-pcm-recovery
i want help please ...
controller unlocker:x35invalid key ... how i can solution this problems ...?
controller unlocker:x35invalid key ... how i can solution this problems ...?IMG_5479.jpgIMG_5479.jpg
please i need help .. i cant open computer my car ...?
Emil [email protected]
thank you for all
