I'll add some stock files and everyone can contribute
Xstages Motorsport
Tuning inquiries:
ECU, TCU, CPC Online Tuning
Whatsapp: +971503383340
Email: [email protected]
Insta: @xstages.motorsport
www.xstages.com
Stock 2019 GLC63S M177
Stock GL550 oem pull
Attached is two files for a 2012 E550 M278 twin turbo v8
First file is the stock rom
2nd is its current tune, shows 650+ tq calculated, and is smooth as stock.
Car is all stock other than being strait piped
Best thing I could recommend to anyone trying to tune one of these, Just raise limits and focus on wot areas.
First richen boost fueling, then
Slowly work up high load tq and load %, keeping boths commanded vs actual inline and scaled accordingly.
Youll max out calculated tq quicker than youll expect and adding anymore peak boost is pointless.
Once you found what peak boost level yielded the highest tq and load %, then focus on the boost curve
Max boost curve should still ramp in like stock but to your peak boost, and command it to carry that peak boost out as far as possible
Timing table I just smooth and adj its max scaling as needed
This adds a safe 150tq+ while keeping everything smooth like stock, in just a few flashes
Abdulaziz T Hadi - E-mail: [email protected]
Stock
Attached is 2015 S550 stock file.
Looking for AMG version if any body have it.
Stock first read.hpt
Do you mean S63 2015?
Xstages Motorsport
Tuning inquiries:
www.xstages.com
I'm looking for AMG version for m278 if it is even existed, not sure if S-class have S550 amg or not.
wanna pump my stock car tune little bit and I feel the safest way is to copy from AMG version.
Thank you for sharing! I found out, that there are quite big difference between A45 AMG and CLA45 AMG (someone should check GLA45 AMG also. I did send feedback to HP tuners and they have been fixed almost all issues I asked in latest beta. Soon should be even more! I did miss couple of important differences. This is good news to us A45 AMG users . Big thank you for HP tuners engineer team! Hope they will add same updates to both/all m133 platforms, because they use same m133 engine and same ECU. Somehow OS aren't same.
I managed to test it and it seems much better to tune this car. Some limiting factor did go away.
My GLA45 stock file.hpt
Here is GLA45 stock file.
Did anyone managed to read C300 or E400?
any MED17.7.2 but not 45 platform, if so please share
Xstages Motorsport
Tuning inquiries:
www.xstages.com
2015 mercedes c63 NA stock.hpt
stock me9.7
Remote Tuning [email protected]
2018 glc 63
Stock AMG GT 63S 630HP M178
