Results 1 to 13 of 13
Thread: 03 Cummins 24v 5.9 SWAP into 08 Ford F350 Frankenstein!!
    Mar 2022
    4
    Exclamation 03 Cummins 24v 5.9 SWAP into 08 Ford F350 Frankenstein!!
    Hi All,
    We are having issues turning off the skim (so we believe ) on our 08 ford f350 with an 03 cummins 24v 5.9 & ecm (this ecm came with SKIM). We turned off the skim using HPT and had our tuner zap the skim code out as well so it doesnt show up in the scanner. The truck wont start, it just cranks, probably not allowing the injectors to fire. I contacted HP support and they said you may need a dodge wiTech device (dealer only) but when i called the dealer they said that it only works for 07 and up and they dont have anything to support that.
    Has anyone done this swap before and can anyone lend some help? thanks in advance.
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    210
    Normally if you had a skimm issue it should start for a few second then die...did you tried to log when starting to see what happen?
    03 cummins,175% flux injectors,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
    Mar 2022
    4
    Quote Originally Posted by MAIDENCR View Post
    are you sure? if it doesnt allow the injectors to fire then how would it run? we tried brake clean and it chugs but shuts off, otherwise it wont start at all. we did not log it, we scanned for codes and there were a few,
    leave the skim on in vcm suite and if wired up properly it will start just fine, 03-05 vs 06+ are different. i drive a few swaps and have no issues
    2010 F-350 03 5.9/848ecm, built 5R110, 30% over sticks, 10mm pump, 64mm Stealth Turbo
    2008 F-350 03 5.9
    Fumminstuning.com
    Mar 2022
    3
    Hey guy. Can you please enlighten us a bit more, I have a 2007 5.9 I need to do the same
    for 03-05 read the ecm which will give the generated file, then flash back in the ecm will be waiting to see/learn the skim which is not there and start fine. if it's turned off it will not run I suspect the map is not correct.
    for 06-07 trucks I know on efi you can turn it off and it starts, 06-07 on hpt the above method worked for a guy I was helping out as well. i will be testing 07.5-09 6.7 shortly but with efi this time
    2008 F-350 03 5.9
    Fumminstuning.com
    Mar 2022
    4
    Exclamation
    Quote Originally Posted by guy-ffc View Post
    It wouldnt start before with skim on, so we turned skim off with a tune and still wont start, we are getting code p1652, which is J1850 comm bus code, are you able to clarify? can you email me your phone number to pick your brain? [email protected]
    Mar 2022
    4
    update, HPT said its not possible to turn the skim off with this vehicle, so we are shit out of luck! thanks HPT -.-
    leave it on flash back in and it should work just fine [email protected] is my email I've done a few of these no biggie
    2008 F-350 03 5.9
    Fumminstuning.com
    May 2019
    Duncan, BC, CDA
    51
    Do you know if the engine ran before you got it?
    If you don't know, I'd check the rail pressure to make sure it builds and you don't have a bad injector.
    Then I'd change the cam and crank sensors. They can cause a no start condition...ask me how I know lol.
    Chay
    Banned
    Jan 2018
    Everywhere
    1,772
    Bad cam and crank position sensors can but not always cause a no start condition, they could just cause a no battery charge condition. Verify things need to be replaced before just replacing for the sake of throwing dollar bills at something
    Jun 2022
    Quote Originally Posted by Jim P View Post
    Hey did you ever figure this out? Having the same problem with my swap, 2008 F550 with 03 commonrail. Cranks won?t start, p1652 code, tried everything, just sent my ecu off to have skim removed. But I still think it?s something else, would love to hear that having skim removed resolved your issue.
    Quote Originally Posted by masongood234 View Post
    these can all be done with hp tuners, this guy got his going we had a few emails. i have done many and no issues
    2008 F-350 03 5.9
    Fumminstuning.com
