Results 1 to 7 of 7
Thread: E85 and fuel pressures
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    472
    Will switching over to E85 effect the HPFP much. After afriend did the conversion with basic boltons, CAI,LTH ,his HP is really realy low and his injector PW is around 3.5ms at idle. His low pressure is fine.
    Is this normal??
    Thanks!
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    307
    Need a log of lift and DI pressure and the tune.
    May 2003
    South FL
    1,592
    That is not normal
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    Feb 2012
    Houston, TX
    472
    Didn't think so. Never tuned a Gen V for E85 so I was not sure if it had any bearing in regards to thr HPFP or how the DI pressures might act.If thats not the case, im thinking the HPFP took a dump out of coincidence.
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    May 2003
    South FL
    1,592
    The DI pressures shouldn't change like that just by going to E85. Technically, enabling the sensor, the DTC and changing the stoich scale would be enough to get have it adjust for the fuel volume properly. But even on full E85 the idle pulsewidth would be a lot closer to 1ms.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    North Carolina
    4,829
    E85 wouldn't have caused that alone. I suspect the high side pressure is low for some reason.
    A log would help know for sure.
    Feb 2012
    Houston, TX
    472
    Switched out HPFP......all is good now.
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
