Results 1 to 6 of 6
Thread: AEM MAP Sensor with MPVI2 Prolink
    Jun 2022
    18
    I have 2014 Mustang GT with VMP Gen2R Supercharger, planning to get the AEM MAP Sensor 30-2130-50 for speed density tuning.
    If I understood correctly I can connect the sensor to the Prolink's analog input and read the output in the VCM scanner.
    The sensor needs 5 volt DC supply voltage and analog ground. Can anyone point me how to wire everything correctly?
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Jun 2022
    18
    Do you know where should I get the 5v supply from? I was thinking to use 12 to 5 regulator but not sure
    Jun 2015
    Aubrey TX
    890
    Quote Originally Posted by shalva View Post
    Good question. I just remembered my WB is 12V
    I would think you could tap into an existing circuit and not need a regulator. Like my E85 sensor Tees into one of my coil circuits.
    Possibly share existing MAF sensor +5?
    Maybe someone who has installed one will chime in
    EDIT:
    Thinking about this, are you keeping existing MAF with this install?
    Jun 2022
    18
    Yes, MAF will be there. I will use MAP for speed density tuning and then remove it.
    Sharing MAF is a good idea, will try it. Thanks!
    Tuner in Training Pappacosworth's Avatar
    May 2016
    Finland
    44
    why not use https://www.plxdevices.com/Vacuum-Bo...7346002191.htm
    it uses 12 v, and it is cheaper
    Ford Mustang Cobra -94. Focus ST 2013
    Coretuning/Moates/HPTuners/Quantum
