Wanted some opinions - running a 2000 Suburban LM7 N/A - Just got my MPVI2 and realized I need a wideband. I have been told the AEM 30-0300 as the best one to get.
Opinions?
Opinions?
Yes, they are good widebands. I've probably bought 3 or 4 of them over the years.
Several different way you can add them into HP Tuners.
If you do get the AEM, the obd2 30-0334 one that plugs into the diagnostic port only works on vehicles 2007 and up so you will need to wire it into your MPVI2 via the pro feature set or you can get a wideband that uses a serial data via usb like a innovate LC2. I like using the obd2 input when I can or the serial data input (LC2) over the 0-5v input because the signal is alot cleaner. Just my preference.
2010 /2SS/Long Tubes/ Magnaflow axle back/LSA Conversion/ 2 bar OS running / Stock Blower Pulley...for now
