Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: FRPP Crate PCM and Aftermarket Calibration Support : Extra Steps
    Nov 2020
    3
    Quote Originally Posted by LastPlace View Post
    Email support Eric very rarely checks the forum.
    Thx.
    Mar 2021
    29
    I had to go this FRPP route with my 2018 coyote 5.0 manual (M-6017-M50B).
    I followed the advice of how to identify my ecu and so to pick the right hardware option. Non of it matches my ecu, so i started playing and the only pick under 'hardware' could read my ecu was 'TC-298, ECM, 2018+ Ford'.
    Now am I having the right one? Am I seeing all setting options? Am I about to blow my ecu when writing to it? If it is wrong, how to move on?
    I already send off a support request, but I am hoping to get solid advice here sooner.
    Tc-1797
    Hi, I have a Continental RMFR3A-12A650-CLB that appears to have no data or file on it? I read it with TC1791 & followed the proceedure laid out in the above intstructions. After reading got the prompt to generate the OSID, hit OK, it earesed & started to write back but timed out at about 95%. It now has no data, will not start, crank over etc. Also when trying to view data with any diagnostic scanner it does not appear to have anything in it & HP Tuners MVPI2 does not recognise it, comes up detect protocol failed. What next?
    Oct 2016
    Poland
    1,771
    this is a blank pcm, serv on the sticker says so. it has to be PMI'd to your car using IDS
  6. #26
    Apr 2022
    Gen 3 Coyote FRPP
    From Eric:
    The Gen 3 Coyote crate engine control pack ECU uses controller TC-298
    Ford Part #: RMJR3A-12A650-AKA
  7. #27
    Apr 2022
    5
    Good morning, I have the same problem. i cant read copperhead ecu from ford frpp control pack. were you able to fix it? it tells me when reading "controller unlocked x7f service not supported in active session"
  8. #28
    TC-298 Picture
  9. #29
    Nov 2008
    TC-298 Picture
    Quote Originally Posted by Snowman79 View Post
    From Eric:
    Would TC-298 work with both manual and automatic control packs?
  10. #30
    Oct 2016
    Poland
    1,771
    Quote Originally Posted by newguy View Post
    Yes...and no.
    I found that hardware is the same, even for 3.5 V6 manual or automatic but you need to not only swap OS but...you also need to work with your eeprom which HPT can't do.
    I successfully reprogrammed F150 2.7 PCM to work as 5.0 Mustang but you need more advanced tools that reads not only flash but eeprom as well.
    The same goes with manual to automatic.
    Funny story: v6 pcm would take v8 file but only 6 cylinders would fire and will work just fine besides that...must be a cyl no selection switch in eeprom.
  11. #31
    Jul 2022
    4
    Quote Originally Posted by Tuningperformance View Post
    Hi, I have a Continental RMFR3A-12A650-CLB that appears to have no data or file on it? I read it with TC1791 & followed the proceedure laid out in the above intstructions. After reading got the prompt to generate the OSID, hit OK, it earesed and began to compose back however coordinated out at legal services personal statement https://www.aussiessay.com/personal-statement-writing/. It presently has no information, won't begin, wrench over and so on. Likewise while attempting to see information with any demonstrative scanner it doesn't seem to have anything in it and HP Tuners MVPI2 doesn't remember it, comes up recognize convention fizzled. What next?
    Service replacement PCM for M-6017-M50A 2015-2017 Mustang Coyote control pack. Comes with the controls pack calibration for 2015-2017 Mustang Coyote engine with automatic 6R80 transmission.
  12. #32
    Jan 2018
    9
    awsome thanks u HPtuner sharing
  13. #33
    Sep 2012
    Southern Germany
    65
    Hi Guys,
    even have the TC-298 from a M-6017-M50B Gen 3 2018+ Control Pack
    unfortunately, i dont get the "set a OS ID" prompt and after Reading a checksum error.
    already sent a mail to support@ but yet didn?t get any answer.
    any ideas?
    ____DH INDIVIDUAL____
    Hemi & LS Tuning in Europe
    www.dh-individual.com
  14. #34
    Jul 2023
    Would anyone happen to have a stock,untouched read from a M-6017-M50A? This is the 15-17 Gen 2 6r80 controls pack. I have a car here that is supposed to have that kit but I get the feeling this is a stock GT PCM that's been PATS disabled.
    Thanks!
  15. #35
    Mar 2022
    17
    Quote Originally Posted by Eric@HPTuners View Post
    All of the aftermarket operating systems we support now have DMRs defined, in the latest beta. The above steps MUST be done to get logging to work on many of them.
    Hello. What are the DMRs ? What is the full name of DMRs ?
  16. #36
    Oct 2007
    Crawfordville, FL
    2,442
    Direct Memory Register, so you can log the actual variables being used.
    Eric Brooks
    HP Tuners, LLC
  17. #37
    Mar 2022
    17
    Thank you very much for the explanation
