Results 1 to 20 of 40
Thread: Unable to connect to VCM
    Tuner V8 Supra Builder's Avatar
    Jan 2007
    Florida
    77
    I just received version 2.1.14.0 and am using it on my Supra LM7 swap. The motor is a 2003 5.3 LM7, the harness is from a 1998 F-body, and the VCM is from a 1998 Corvette. I do not know the history of the VCM (bought it on eBay).
    When I plugged in an Actron OBD2 scanner it gave me code 1518, electronic TB error. The car has a cable TB.
    I have verified all wires to the PCM as well as the OBD2 port.
    When I tried to use HPT to "read entire" the VCM, I get "Connection Error"
    "Unable to connect to VCM. Verify cable is connected and key is in the run position."
    Why can the Actron read the VCM and HPT cannot? What am I doing wrong or is it something else?
    My laptop is Windows XP home. The laptop is running on AC power and the car's battery was fully charged. I quit all firewall and AV programs, the only program running is HPT. The laptop is offline.
    The car would not start after it was completed, the fuel pump wire is not grounding the pump to activate it, I jumpered this and it still does not start.
    Currently (2020) swapping an LM4 5.3 and an older 4L80 into a Dodge Durango. My prior projects include Chevy Gen 1 V8 into an FB RX-7, Gen 3 V8s into an FC RX-7, a MK3 Supra, a BMW E34, and an LT1 into a 280Z. Still have the Datsun, a 383 LT4 Trans Am, and some bikes.
    28,313
    Did you install the drivers on the install cd?
    Jan 2007
    Florida
    77
    Yes, I followed the install instructions (installed but did not run program, then plugged in cable, loaded drivers, then ran program) and USB channel A and channel B installed with no problems.
    I did have to disconnect the cable from the car after I started the program for a firmware update, but this had no error messages as well.
    I attached a wiring diagram I made for this swap, it shows the OBD2 port. I used the tan wire to pin #9, not sure if this was needed (UART function) but since it was there on the '98 car, I put it in mine as well.
    One other thing, are the pinouts the same for the Corvette as the Camaro? I think the VCM I have came from a Corvette. The part number is the same as the Camaro, so I figured they would pinout the same.
    Jan 2007
    Florida
    77
    Update
    I rebooted the laptop: No difference
    I plugged the cable into my '98 Durango (also OBD2): Same error message
    I pulled the OBD port fuse: Program said no vehicle power detected
    I reinstalled the USB drivers (both already showed as HPT -like the help file showed- under the device manager) : No difference
    Synopsis: Still can't connect, appears to be a computer or interface problem due to lack of connectivity to the other vehicle.
    Next step is to uninstall the program and start from scratch.
    Dec 2006
    19
    I am having the same problem right now with my Trailblazer SS. I just got it downloaded the newest version. I might have missed all the drivers any one want to point me in the right direction to make sure i have all of them. my error message is this "The interface was not found or is not responding. Verify it is connected properly and the vehicles diagnostic port has power"
    Any help????
    Not trying to steal your thread but i figured we are looking for the same answers
    28,313
    Quote Originally Posted by V8 Supra Builder
    Try connecting to a different GM vehicle we support...all OBD2 are definitly not made equal
    28,313
    Quote Originally Posted by rfatt16
    Any help????
    was everything working BEFORE you downloaded the newest version? Or at least give us some details as to what exactly happened.
    Jan 2007
    Florida
    77
    No problem, this is why I posted here as well as sending an email to support per the guidelines. The nice things about forums is that they can help people with the same problem now and years from now.
    I did a "clean" re-install: uninstalled application then USB drivers then rebooted then reinstalled application and USB drivers (my application number was still there, so not all of it was uninstalled). Same installation sequence, same result.
    Jan 2007
    Florida
    77
    Quote Originally Posted by foff667
    I'll have to go out & buy one... <vent> and after the $ spent here that is not within the realm of possibility </vent>
    My other vehicles (except the Durango and project RX7) are like 400 miles away, and none of them are OBD2 anyway.
    28,313
    problem is we don't support dodge as of yet so its not going to work...they use a differen protocal than gm does.
    My first assumption is an issue with the wiring at this point.
    Are you able to grab an infolog off of the vehicle? http://www.hptuners.com/help/demos/infolog.swf
    Dec 2006
    19
    Nothing has worked. I downloaded and tried to plug it in. When pluged it in, i heard the laptop make the beep where it means something new has connected. Also when i plugged it in to the car port the HPT box itself the power light lit up. At the very bottom of the screen it says cable status:Not Found. Where can i download the usb drivers???
    28,313
    http://www.hptuners.com/help/getting...stallation.htm
    We always recommend starting with the disk that comes with your hardware...everything you'll need to get up and running is right on the disk.
    Dec 2006
    19
    I know thats the easiest but i didn't get the cd when i got the tbss. I bought it and it already had it with it. The guy i bought it from couldn't find the cd.
    Sep 2002
    Chicago, IL
    6,397
    We got this guy Not Sure, ...
    Dec 2006
    19
    Quote Originally Posted by Keith@HPTuners
    I went to this link and downloaded the zip file. when i went to open that it asked me to save so i did i hit open and my winzip opened then it went to a little screen that has 5 thinkgs on it FTD2XX.dll, ftd2xx.inf, FTD2XX.sys, FtD2xxun.ini, Ftdiunin.exe I unzipped it and placed them in the HPT file. anything else i need to do. shouldn't there be a prompt after they are unzipped?
    Jan 2007
    Florida
    77
    Did the infolog, here are the results (serial and application numbers removed)
    Operating System: Windows XP
    Microsoft .NET: 1.1.4322.2032
    VCM Suite Product: VCM Editor 2.1.14.0
    VCM Suite Key:
    VCM Suite ID:
    Credits purchased: GM - 8 Ford - 0 Dodge - 0
    Credits used: GM - 0 Ford - 0 Dodge - 0
    Credits available: GM - 8 Ford - 0 Dodge - 0
    License slots available: 408
    No Vehicle Licenses
    ID:
    Date: 06/14/06
    Hardware: 121
    Firmware: 110
    Part Number: 6221
    Rom Status: 0 3F 0 82 0 1 0 FC FF
    SPI Info: 0 0 0 0 0 0 0 0
    Config: CC 0 0 0 0 80
    System Status: F7 0 0 0
    Comm. Status: 0 0 0 0 0
    On Time: 0:57:33.715, 51:24.130
    Type: Unknown
    VIN: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
    VCM ID: 0J0CFZ6346
    BCC: ????
    ECM Seg 1 ID: 0
    ECM Seg 2 ID: 0
    ECM Seg 3 ID: 0
    ECM Seg 4 ID: 0
    ECM Seg 5 ID: 0
    ECM Seg 6 ID: 0
    ECM Seg 7 ID: 0
    ECM Seg 8 ID: 0
    ECM Seed: 0
    28,313
    http://www.hptuners.com/help/index.h...stallation.htm
    the instructions on installing usb drivers is all right there.
    Dec 2006
    19
    I see that but nothing happen. I unplug/plug in the Box and it dings at me but nothing happens. I do not get a prompt for the drivers. i was wondering if i needed to do something else to get that prompt.
    I'm about ready to say F it and try to find/buy a cd for it.
    28,313
    Did you check the manage drivers window like it shows on that page to see if it recognizes both A & B?
    28,313
    VCM Suite Key:
    VCM Suite ID:
    No Vehicle Licenses
    ID:
    Date: 06/14/06
    Hardware: 121
    Firmware: 110
    Part Number: 6221
    Type: Unknown
    VCM ID: 0J0CFZ6346
    BCC: ????
    ECM Seg 1 ID: 0
    ECM Seg 2 ID: 0
    ECM Seg 3 ID: 0
    ECM Seg 4 ID: 0
    ECM Seg 5 ID: 0
    ECM Seg 6 ID: 0
    ECM Seg 7 ID: 0
    ECM Seg 8 ID: 0
    ECM Seed: 0
    Your going to need to have the PCM programmed by a dealer with a tech 2 so that you have a valid vin #
