Results 1 to 11 of 11
Thread: 2015 Chevy 5.3L Help
    Hi all,
    I just did a DoD delete on my 2015 Chevy Silverado. It has a Gen V 5.3L.
    I installed a stage 2 cam, new lifters, the DoD plugs and new valve seals and springs.
    I also installed the Phase block in front on the Cam Phaser.
    When I went to start it it ran really rough and gave me a P0016 code. Now it won't start at all.
    When I took the timing chain off(without removing oil pan), I made sure the #1 cylinder was at T.O.C.
    I know it was hard getting the chain back on, however, IF it was off, it was only a tooth.
    Am I doing something wrong in HP Tuners?
    I disabled the DoD system already.
    I tried reloading my original file I made before anything.
    It just won't run. It starts runs for 5 seconds and dies.
    I also did the Crank sensor relearn.
    Any ideas that might help?
    I am hoping I can get it right with tuning instead of having to remove the timing cover again!
    Any help would be so much appreciated.
    Thank you,
    Todd
    14,066
    Post the tune and log file if you want more help.
    Sorry about that.
    1st vvt removal attempt.hpt1st run.hpl
    I didn't look super close through your tune, but I think its unlikely any Stage 2 sized cam is going to be happy idling at 550 rpm or less.
    Tuning Addict
    10,887
    You can't correct a 18-degree cam timing error with the tune file, if that's what it turns out to be.
    edit: bad math, sorry - 16-degree. More or less.
    Thank you all.
    Sep 2022
    So dynospeed in memphis has my 2015 Chevy Silverado.
    This is what they are telling me I don?t have access to the tune files or I?d post em.
    its pulling timing sometime while cruising out of the blue. Anyone run into this before?
    LSXceleration Gen V L83 L86 LT1 LT4 DOD/AFM Delete Kit
    16 (full set) #25341990-16 Lifters +$79.95
    Choose Lifters for Gen V
    DOD Delete:
    Choose Head Gaskets for
    LSXceleration 5.3L L83 #14-22325 +$6.00
    Gen V DOD Delete:
    Choose Head Bolts/Studs LSXceleration OEM Bolts #156959
    for Gen V DOD Delete:
    Choose DOD Plugs or
    LSXceleration DOD Oil Block Off Plugs #54224-8
    Valley Cover:
    Add Gen V Timing Cover
    Add LSXceleration 14-34614 +$6.67
    Damper Seal:
    Add Gen V Water Pump
    Add LSXceleration #16-57430 +$6.37
    Gaskets:
    Add Gen V Exhaust
    Gaskets:
    Add LSXceleration #14-57093 +$15.94
    Add Valley Cover Gasket:
    Add Intake Port Gaskets:
    Add Chevrolet Performance 12623104 +$11.90
    Yes, add 14-26354-8 for Gen V L83 L86 LT1 +29.00
    Add Gen V Valve Cover
    Add LSXceleration #14-19787 +$8.50
    Gaskets:
    Add Balancer/Crank Bolt:
    Add Gen V Cam Phaser
    Bolt:
    Add LSXceleration #22-57840 (Wet Sump) +$4.99
    Add LSXceleration #22-81018 +$42.84
    Add Cam Retainer Plate:
    Add # B32270 +$17.97
    Add Gen V WT Solenoid
    Add LSXceleration #14-23437 +$3.79
    Gasket:
    Add Gen V DOD Delete
    Cam:
    Add LSXceleration Stage 2.1 Cam # 2224301 +$399.95
    Add TV Sealant:
    Add Chevrolet Performance 88864346 (2.65 oz) +$11.66
    LSXceleration Gen V LT Valve Spring Set 81120-16 - 0.555 Max Lift
    GM LS Metal Body Hat Style Valve Stem Seals 140543-16
    LSXceleration Cam Retainer Plate Bolt 22-61455
    LSXceleration 7.850 x 3/8 x .080 Wall Pushrods 63785-16
    COMP Cams GM L92 & Gen V LT1 VVT
    Cam Phaser Lockout Kit 5465
    (Unlike the Summit Racing description, this kit completely
    locks the phaser from moving. It does not limit movement
    to just 20 degrees, it limits it to 0 degrees. Therefore it will
    result in diagnostic trouble codes when the phaser doesn't
    move as it's told to do by the ECM, which means a user
    will need to pay for a ECM tune that disables the DTC.)
    This is from summit reviews
    I know the shop did a cat delete
    New drop in k&n filter
    Checked lifter preload
    And carven exhaust bolt on
    Jan 2024
    6
    I'm new, how do i create my own post on here with a similar issue?
    Tuning Addict
    7,172
    Post new thread at top of the related engine forum. Gen V is your DI motors for example. Make sure to include log and tune, full details and what it's doing. To upload the log and tune click on go advanced - manage attachments.
    ~Greg Huggins~
    Jan 2024
    6
    Thank you!
    Oct 2023
    4
    Hey by any chance do y'all got a 2015 chevy Silverado base map tune or stock tune map previous person who tuned this truck didn't even save the stock map and i cant find a way to get ahold of the guy. If yall got one and can send it to me that would be gladly appreciated and save me a massive hard headache thank you!
