Results 1 to 12 of 12
Thread: I test the MAF and got the numbers that don't make sense
    On my 2014 GT500 I tested the MAF sensor and the scanner says it should be between .7 and 1.0V at idle. It was was bouncing from .4 to above 4.5V. I have change it would a couple months ago. Any thoughts as what would cause this. I have a 124MM JLT cold air on it and had the stock sensor on it and replaced it with an after market stock one.
    Marty
    I just a brand new one in and I am still getting the results on the test. Do I need a performance style MAF sensor and not a stock one with the JLT and if I have a bunch of other mods.
    Tuner in Training Pappacosworth's Avatar
    May 2016
    Finland
    44
    Are you sure that you have correct maf, Ford started using frequency based maf about that time.
    Ford Mustang Cobra -94. Focus ST 2013
    Coretuning/Moates/HPTuners/Quantum
    That is a good question. When I went to the parts store and told them what I had that is the one they told me is for the car. That is also what the scanner said when it decoded my VIN. But that is a good question. I guess I am not sure how I would know. Do you know of a way to check and find out?
    Mar 2018
    448
    Log maf period/time
    I was doing some more research and it look like they went to frequency in 2010+. I am logging MAF lb/min. Do you know how I would be able to test to see if it is ok. Like with the scanner the V should be in the .7 to 1.0 at idle. It looks like it is running about 4.86 when I first started it and then after a few minutes of idling it had dropped to 2.82. When I was revving it some it was anywhere from 1.92 to 5.86.
    Mar 2018
    448
    Quote Originally Posted by K44 View Post
    Log maf period/time
    Forget about volts
    ok. I was just asking that question. Those numbers that I gave where not in Volts. That was the number in lb/min. So this " It looks like it is running about 4.86 when I first started it and then after a few minutes of idling it had dropped to 2.82. When I was revving it some it was anywhere from 1.92 to 5.86. " Or is there another option you were talking about. In the log when I go to the MAP for the chart is is giving amount per time (lb/min, g/s, etc.) Sorry if I was not understanding. I think I figured out what you are meaning. Here is a snipit of the log I setup. Is this what you are talking about.
    Mar 2018
    448
    This
    ok. This is what I have. I added those. I have info from them.
    Mar 2018
    448
    You only need the 2 that I highlighted
    ok. I have a log with that data. Is there a range or what should I be looking for when looking at those two PID/channels?
