Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: Boosted lt1, high compression and timing
    Sep 2009
    765
    Quote Originally Posted by anniversaryss View Post
    I did some digging and the knock sensor stuff is odd.
    02 Express 5.0 uses KS2
    97 LT1 (mine) KS2
    02 Express 5.7 KS7
    I compared the 02 5.0 (KS2) to the 02 5.7 (KS7) with efi live. Efi has sensor sensitivity settings as well. Either way both tuned were EXACTLY the same for knock sensitivity settings . So its possible to say the KS2/KS7 sensors should interchange.
    O well. Its been a while. I haven't had a chance to get out. I'm going to try 16 degrees and work from there.
    My 1983 G20 305 Q-Jet w/ ESC used a KS2. When I put a 350 in that van I put a KS7 in it. We used to do the same thing on 305 to 350 TBI swaps.
    Sep 2017
    736
    Quote Originally Posted by Fast4.7 View Post
    You're saying they are interchangeable?
    Sep 2017
    736
    Have you actually seen the knock sensors report anything? I still haven't had a eficonnection or torquehead swap report any knock at all.
    I've seen up to 5 degrees in the lower rpms before 24-3600rpm but I think it was false knock tho.
    I've never seen any knock up top at wot but I think 33 degrees NA was fairly low even with TFS heads.
    Sep 2009
    765
    Electronically they are, frequency they are not. The KS2 is usually used on a smaller 3.735" bore. In TBI conversions or 350 swaps the KS7 is usually used on a 4" bore.
    Sep 2017
    736
    Ah so it would be beneficial to swap to a ks7 then?
    Its kinda odd tho that my lt1 is a 4" bore iirc and uses the KS2
    The least I could do is buy a KS7 and chnage it and see what happens
  6. #26
    Oct 2008
    Mebane NC
    475
    Is there a GM part number for the KS7 or are you just buying based on the "KS7"
  7. #27
    Sep 2017
    736
    I just go by KS7 which is standard motors
    I believe the GM is 10456288
    Acdelco I believe is 213-324
  8. #28
    Sep 2017
    736
    The 5.0 l30 has a different part number than the 5.7 l31
  9. #29
    Oct 2008
    Mebane NC
    475
    Thanks, just wanted to clarify. I got (2) 10456288/213-324. In the process of going through my engine again and will be replacing the ones I was using.
  10. #30
    Sep 2017
    736
    Yeah according to GM parts direct and advance auto those are the correct part numbers for the 2002 Express 5.7.
    The ks7 is like 30 bucks the ac delco is 60
  11. #31
    Sep 2017
    736
    I installed the KS7 today. Going to get some seat time in soon
  12. #32
    Sep 2017
    736
    I'm up to 18 degrees and I'm at 14.5-15 psi. A little more than expected.
    I havent seen any real knock event yet. Tuning on 93 at the moment and e85 sooner or later.
    Also using the KS7 or Express van sensor
  13. #33
    Oct 2008
    Mebane NC
    475
    Thanks for the update
  14. #34
    Aug 2009
    Calibrating
    3,379
    You’re a ways off on timing still, mid 20s be the sweet spot on 93 with that combo
    Oops sorry at 11.1 CR you’re fairly close to being maxed on 93 octane, I had Lower CR in mind..
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  15. #35
    Sep 2017
    736
    Thank you Ben. Yes I'm working in it slowly for now. As you said I feel like I'm pretty close to being set with timing until I run E85.
    I'll keep updating as I go. Once a week is slow moving lol
  16. #36
    2,975
    A dyno would really help for that. I wouldn't trust that the knock sensors define the limit. I'm still not sold on 411 swapped LT1's and normally functioning knock sensors.
    Seems like all of them miss picking up real knock.
    Tuner at PCMofnc.com
  17. #37
    Sep 2017
    736
    Yeah I'll get back on the dyno sooner or later I'm enjoying street tuning for now. I prob wont up the timing anymore until I get on the dyno
  18. #38
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    197
    If you aren't using my dyno or Alex's loaded hubs on Grand Island just do your tuning on the street or track. Inertia dynos are only good for measuring horsepower & torque, they are useless for tuning fuel/spark (finding MBT)
    Western New York's Performance Headquarters
    716.830.0506
