Results 1 to 5 of 5
Thread: 2021 Y62 Nissan Patrol VK56 supercharger
    Jan 2012
    Cessnock NSW
    73
    Hey Guys, I've got a customer coming to my shop soon to get a supercharger fitted to his VK56 patrol, I've never tuned a VK56 before, so I have a few questions about the Nissan tune
    Can the stock nissan tune be made maffless or do I need to retain the maf?
    Is there a tuning procedure or process to follow? what tables do I need to modify apart from spark and fueling?
    Which spark table is the main spark table? what total timing should I be aiming for with around 5 psi?
    Is there a VE map to tune apart from the maf or is the maf the primary source of fueling?
    It will be only running 5 psi from the top mount charger and have full exhaust system including headers.
    I have plenty of experience tuning LS supercharged stuff, I'am just not familiar with nissan PCM.
    Thank you for any help
    Apr 2012
    12
    Definitely needs to retain the MAF.
    In my experience and from my understanding they seem to behave best when tuned as follows. Calibrate the MAF as you normally would, but keep in mind the MAF only flows around 550g/s and also determines the load percentage for the rest of the tables.
    Make sure fuel trims are turned off.
    Open loop target lambda does what it's name suggests.
    Fuel compensation tables do as the name suggests and also work to achieve your target fuel map, especially where it runs out of MAF
    Timing is done with the trimming tables, but keep in mid the numbers don't correspond to actual timing.
    Its also important to modify the estimated torque tables accordingly for transmission longevity
    Also, being a 2021, depending on build date u may be running a version of the firmware that is largely unsupported by HP tuners and may not have all the required tables available and also won't have as many available channels in the scanner to work with.
    All of this is just my findings from tweaking with my car for the last 4 years or so and could be completely wrong but it has worked well for me.
    Hope this helps 😎
    Nov 2009
    All Around
    3,149
    the newer platforms timing is a little different make sure looking at all factors/adders
    Jan 2012
    Cessnock NSW
    73
    Which spark table do I modify for the main spark? TIA
    Quote Originally Posted by SultanHassanMasTuning View Post
    Nov 2009
    All Around
    3,149
    post file
