Results 1 to 14 of 14
Thread: L83 swap into scout ii
    Sep 2022
    Brenham, TX
    7
    Hey guys, totally new to the LT platform. I'm boggled over the amount of discrepancy on fuel pump and control information on the webs/forums.
    Here is the dilemma. I've swapped a low mile L83/6l80 into our 1978 Scout II. We are using a Howell harness and ECM. Everything is plug and play and really easy. Except when it comes to supplying fuel.
    We started out with a Walbro GSS342 pump and ran it returnless. Had the inline pressure sensor up near the engine. FPCM is mounted on the firewall and plugged in. The tune is set to be controlled by the FPCM like
    the original engine was in the truck. Would not start or run. Truck would run with injector cleaner being sprayed in the intake but that is it.
    Reading online, we have the wrong fuel pump installed. This is where we swapped to an OEM pump from napa and made it work inside of the Scout tank by removing the pump from the assembly and installing it in the Scout
    assembly. We also added a Aeromotive Fuel Pressure Regulator on the firewall and a return setup. We are getting a solid 72psi out of the regulator and still will not run unless we are spraying in the intake.
    We have went over every connection and plug on the harness.
    Yes there is an inline filter and it is new. All -6 hose on the system.
    Does a new FPCM need to be programmed to the system or will it work correctly right off the shelf?
    What would you recommend we do about fueling issues? I'm leaning on something not being right with it and I'm not against starting over with the fuel side completely.
    Should the whole FPCM be tuned out? Or is it even a possibility?
    All help is appreciated.
    May 2022
    DFW TX
    25
    I didn't run the fpcm and am fine with the 58psi from the vette filter/regulator. you might be dealing with a different issue. Always run extra electrical power when first starting and get the rail pressure up. Did you already try pulling codes and data logging everything with just electrical power?
    Sep 2022
    Brenham, TX
    7
    Quote Originally Posted by shonuff53 View Post
    I did, it has been a minute. I will get them pulled again today and post them up. I have a borrowed HPT and a regular hand held code puller. Nothing fancy.
    I'm not sure I understand the extra electrical power.. As in having a charger on the battery?
    May 2022
    DFW TX
    25
    Yes, charger or jumper it to a running car
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,018
    Not sure im following, you have 72 psi fuel pressure, but trying to figure out why pump and/or module isnt working.
    Sounds like your chasing the wrong end, if you have 72 psi fuel pressure, then the module and pump are working
    to me it looks like injectors are not working, probably due to vats not being properly disabled to run stand alone
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Sep 2022
    Brenham, TX
    7
    Quote Originally Posted by mbray01 View Post
    VATS is off, I resent the ECM to Howell to confirm everything was correct. Definitely have 72psi at the regulator. Where it goes or what happens from there is what has me stumped.
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    Please list the DTCs that are being set (or pending).
    Sep 2022
    Brenham, TX
    7
    Quote Originally Posted by Shrek View Post
    P0192 - Fuel Rail Pressure Sensor A Circuit Low Input
    P0315 - Crankshaft Position System Variation Not Learned
    P057C - Brake Pedal Position Sensor Circuit Low
    P127C - No DTC Definition Found
    P2535 - Ignition Switch Run Start Position Circuit High
    Nov 2011
    753
    Quote Originally Posted by jrodyoung80 View Post
    Thank you for posting the DTCs being set - that was very helpful.
    DTC P127C is Fuel Rail Pressure Sensor 2 - Low Voltage.
    In a custom vehicle (Hot Rod) conversion ALL of those DTCs should be set to "Not Reported". Howell Engine Development builds an esthetically pleasing wiring harness, but module programming is not one of their strengths.
    These active DTCs may (or may not) be the cause of your no start condition - but they are certainly not helping your situation.
    Fuel pressure anywhere between 58 PSI and 75 PSI should work just fine - however, this will also depend on how Howell configured ECM parameters 7030 through 7035 in the E92 ECM calibration.
    Gen 5 conversions are extremely unforgiving regarding what all may contribute to a no start condition.
    Sep 2022
    Brenham, TX
    7
    Thank you @Shrek for the insight. Do you have a good lead on someone I can send this ECM to so I can have that issue resolved?
    Nov 2011
    753
    I am not from your area - Texas is a big place - there must be some reputable tuners available.
    Dyno tuning facilities are great at dialing in the airflow model - but are generally not overly knowledgeable regarding the intricacies of a conversion project.
    The "best" solution for you, is finding a knowledgeable tuner who makes "house calls".
    Sep 2022
    Brenham, TX
    7
    Here is my tune file, I messed with some MAF values I read from YouTube. Probably all wrong lol.
    Sep 2022
    Brenham, TX
    7
    I have attached the log file for reference.
    Jun 2010
    293
    make sure your swap has the correct high pressure sensor for your app. 3 pin vs 4 pin. double check the 2 connectors that goes behind intake. they can be mixed and will make this issue
