hey guys.. this is my first post. here it goes!
so I installed some new parts on my 02 Tahoe 4wd, ill list below. the tune I got from my local tuner is far from my exceptional. I've gone 4 rounds back and forth with data logging and tunes that they send back. It's like my concerns are not being addressed.
for example:
running rich - tuner verified that
idle is too low
stalling while going from drive to reverse, not all the time.
stalling while turning into parking spots etc. again not all the time.
feels low on power at lower rpm
while at 3/4 throttle from a dig feels slugging, after 3k rpm its very noticeable that the tune feels more spicy. its like flipping a switch. something isn't right.
the trans shifting is probably the most frustrating thing.
1st to 2nd- is fine, but really hard at WOT
2nd to 3rd- depending on throttle goes in and out of lock up it feels like it's searching. also at WOT it'll also do this
3rd to 4th- hangs in 3rd a lot longer than it should, for example I'll let off throttle in 3rd it stays in 3rd and will eventually shift to 4th. 4th also searches like 3rd.
normal highway speeds normal driving goes in and out of lock up
if i want to pass someone on the highway feels like I need to give it lot more throttle than I should for it it downshift
my tow /haul button was supposed to have a more aggressive shifting table.
could someone look over my tune and data logs. Am I being over critical? The drivability just isn't there and I've lost all conference in my tuners abilities.
thanks in advance for any advice or edits.
engine spec:
* Horsepower: 450+
* Torque: 420+
* Block: Seasoned OE LM7/5.3L iron
* Bore/stroke: 3.800-3.820 in. x 3.622 in.
* Year range: 1999-2007
* Displacement: 323 C.I.D.
* Crankshaft: OEM GM 3.622 in. stroke internally balanced 24-tooth reluctor wheel
* Connecting Rods: OE GM forged powder metal 6.093 in.
* Pistons: Hypereutectic flat top
* Piston rings: Moly
* Compression ratio: 10:1 compression
* Camshaft: Summit Racing Pro LS Roller
* Camshaft specifications: Lift- 550/550, Duration @.050- 222/232
* Camshaft bearings: Installed and clocked to OEM position
* Cylinder heads: #799 OE aluminum 64cc 2.00 in./1.55 in. valves
* Freeze plugs: Brass installed and sealed
* Rocker arms: OE powdered metal 1.7 ratio
* Oil Galley plugs: Installed and sealed
stock flex fuel injectors
stock fuel system
stock intake
long tube headers 3" collectors
high flow cats
3" x-pipe - deleted y-pipe
dual 3" all the way back
magna flow mufflers
cam specs:
part number sum-8713r1
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 222
Exhaust Duration at 050 inch Lift: 232
Duration at 050 inch Lift: 222 int./232 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 284
Advertised Duration: 274 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Valve Lift with Factory Rocker Arm Ratio: 0.550 int./0.550 exh.
Lobe Separation (degrees): 112
trans specs:
Media Blast Transmission Case
RPM Level V 3-4 Clutch Pack
RPM Reinforced Sunshell with Collar and Bearing
Heavy Duty Double Caged 29 Element Sprag
4L65E Low Roller Clutch
Billet 4th Gear Servo
Transgo HD-2 Shift Kit
Corvette Servo
Wide 2-4 Band
Updated Aluminum Accumulator Piston
Bushing Kit
New Shift Solenoids
New GM Valve Body Spacer Plate
GM Filter
RPM Spec Clutch and Band Clearances
Seal & Gasket Kit
RPM Sleeved Input Drum
Billet Over-Run Piston
GM 5 Pinion Planetary Gearsets ? Front and Rear
Dyno-Tested Before Shipping
2200 stall
3.73 gears
2002_Tahoe_222-232 LTH 91 oct 3.73 2200 stall.hptdata log after tune #4.hpl
