Results 1 to 15 of 15
Thread: Need help tuning for 03 Yukon 5.3 CNVRT to flex fuel
    Oct 2022
    SoCal
    10
    Hello everyone. I currently have a 03 YUKON XL 5.3 that I would like to convert to flex fuel as gas prices are ridiculous here in California.
    I have installed the typical Continental type FF sensor and ran the signal wire to pin 56 on the blue connector of the ECU. Changed everything I could find in the tune related to flex fuel. Ecu does not display ethanol content. If someone could help me out and look at the attached file to possibly see if I missed something bi or if I have done it wrong to begin with. Thanks in advance for the help.
    Banned
    Mar 2022
    Indiana
    4,289
    Apparently you have to use an entirely different OS.
    https://forum.hptuners.com/showthrea...ex-fuel-enable
    Are you sure you'll be saving money? e85 would have to be less than 73% the price of 87 octane (e10) for it to make sense. I save money running e30, but that's because the price of premium gas makes it worth it.
    Oct 2022
    SoCal
    10
    I found a 02 Yukon flex in the repository but not sure how to flash the OS portion. Is there some guide or hints on how this is done? Rest of the calibration tables look the same in comparison. Thanks
    14,066
    2002 is a P01 computer and your 2003 is a P59 controller, you can't flash that file.
    Oct 2022
    SoCal
    10
    So I can look for 03 to 05 Yukon files? Still need to flash the OS as well? Any how to on how to flash the OS? Tia
    Jul 2020
    41
    The file you need would be for an L59, VIN code Z (8th position of VIN). Common in 03-07 Tahoes and Yukons.
    Banned
    Mar 2022
    Indiana
    4,289
    Attached is a Flex Fuel VIN Z from the repository. Idk if you're AWD or not. You may wish to browse around. FYI to check the VIN, OS, etc., you click on the button that looks like a page with a blue upside-down exclamation mark in the VCM Editor toolbar.
    Use this tool to compare and then change the appropriate parameters in the attached file to match it to your vehicle. Injectors would be one of those, obviously.
    https://www.gmforum.com/vindecoder.php
    You have to write entire the tune file (save a full backup of yours first). That means that you'll have to pay for more credits to do so.
    Then change your VIN.
    https://www.hptuners.com/help/VCM-Ed...k%20Commit.%20
    Oct 2022
    SoCal
    10
    Thanks for the info. Will be back with the results in a couple of days.
    Oct 2022
    SoCal
    10
    THANK YOU. That worked and now up and running. Appreciate the help.
    Banned
    Mar 2022
    Indiana
    4,289
    You're most welcome
    Oct 2022
    SoCal
    10
    UPDATE; Used the SUV this weekend to tow my drift car out to the upper desert and she performed beautifully. Seemed to have more torque uphill ran smoothly.
    Noticed that the fuel gauge calibration is off a bit as the gauge shows lower than actual. Think there was a section for that in the tuning. Will check that out soon.
    Overall satisfied with the conversion.
    405
    3,231
    Those vehicles could have come with different size fuel tanks. Just compare the settings in the Fuel System tab to the ones in your vehicles original calibration and copy over any differences.
    Sep 2009
    1,150
    You will need your stock tune and injectors come smog time.
    Oct 2022
    SoCal
    10
    Just an update,
    It has been a year now and everything runs great. Vehicle has just passed CA smog check as well today with the tags due next month.
    Banned
    Mar 2022
    Indiana
    4,289
    Hey awesome. Can't believe it's already been a year.
