Results 1 to 9 of 9
Thread: Nag1 Tune
    Dec 2018
    18
    Nag1 Tune
    So I have a 2013 Charger RT with the nag1 trans and I have a dings VB and a 3200 rpm stall. I wanted to see if maybe someone could look at this tune. I just got a new TCM and I want to install a tune in it just want to make sure looks good to a trained eye My car does have the Adaptive Cruise but I did the tune on my old TCM I somehow broke my cruise.
    Thx
    Stock Nag1 test1 TCM.hpt
    Tuner in Training jefo's Avatar
    Jul 2022
    37
    Is this tune from Dings?
    Dec 2018
    18
    Quote Originally Posted by jefo View Post
    I had to get a new TCM and noticed that there was a difference in a couple of the pages between the new tcm and the old and I copied as much of the old to the new as possible. But yeah for the most part this is from Dings.
    Dec 2018
    18
    I did install this tune. But if I have the traction control turned on and I try and do a WOT pull. I end up blowing through the transmission and causing a over RPM fault and have to stop and turn off the car and basically rest the transmission.
    Quote Originally Posted by weaselsmopar View Post
    increase the limp mode rpm limit
    Dec 2018
    18
    Thanks for the info. Trans is behaving very well now. Nice solid shifts up and down. Also have not had problems with any pulls with TC on or off.
    Mar 2009
    S. Florida
    583
    Are you able to share the current tune?
    Oct 2017
    30
    Quote Originally Posted by coanan View Post
    how do you like the SHR components? I did some searching and came across some posts online where another brand valvebody wasnt what it was cracked up to be. Just 2 welded holes on the separator plate and missing screens on the solenoids.
    Mar 2009
    S. Florida
    583
    Quote Originally Posted by PoppyPreston View Post
    Sorry for late reply. Trans is great, I'm pushing 1000hp. Wish it was a 8HP90 though.
    Think there is more to the "just two welded holes" from my experimenting.
