Hi guys,
I need a factory oem files from sierra 5.3 flex 2016 to put on mine 5.3 gas
Thx
Hi guys,
Thx
Repository has 2. Here's 1.
2016 53 Silverado Repository.hpt
Hawk
It may show that the flex is enabled with the virtual sensor but the stoich table is 14.1 across the board, so it never actually uses the flex fuel feature.
Thanks you for this map... But i need a map with flex se'sor oem
Good luck finding one with the actual sensor.
All you have to do is look for the 2014 Silverado file and copy over the flex fuel tables, those came from the factory with a sensor in the fuel line. There are plenty of files in the tune repository on your customer page.
Even easier than the E38. The K2XX trucks have the harness already down on the crossmember. I made an extension harness because I plumbed the sensor on top of the fuel tank. Enable it in the tune and away you go.
That borders on cheating! Appreciate the info.
Hawk
