Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Thread: Transbrake for hp80??
  1. #41
    Cool, ill take a look and see if i can do it
    2019 challenger rt
    k&N cold air intake
    92mm hellcat throttlebody
    ported 392 intake manifold
    ported eagle heads
    Cammotion custom 222/234 cam
    stainless works long tube headers and catless mid pipes
    3' catback with h-pipe & pypes violator mufflers
    e-85 tuned
    3.70 lsd
  2. #42
    Quote Originally Posted by Homer View Post
    I prefer the PC version as I find the Android version does not always execute commands properly.
    https://www.alfaobd.com/download.html
    So i cant connect to anything. All it says is there is no control unit found. So how do i go fixing that?
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
  3. #43
    Mar 2018
    Illinois
    873
    what interface are you using and in what mode...USB, wifi, Bluetooth? Also what does your advanced settings look like? Remember, alpha does not work with the HP tuner interface.
  4. #44
    Im useing the usb. I can get it to reconize the device, but i cant connect to the vehicle. Says its not there
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
  5. #45
    Jun 2021
    Quote Originally Posted by duster451 View Post
    I have a 2019 1320. The transbrake seems to be intigrated into the radio / media center. If you look at the factory replacement radios you will see that they specify "transbrake". The transbrake does not have a rev limiter from the factory. You have to hold the RPM's at a certain range with the gas pedal.
    Are you able to share your bcm read? Apparently people don?t want to give it up..
  6. #46
    Jan 2022
    931
    what are you trying to do?
    you know its not a real brake... it uses the abs
    can add it to a non 1320 or HC with a tazer
    as far as holding rpm that is a different box (2 step)
