I bought a cheap, used laptop just for tuning but when I copied and pasted my last few tunes from my other laptop it says I don't have a license to modify the tune file.
What do I need to do to have permission to change and "Save As" a file?
2017 Camaro SS, Flow Tech axle back, Roto Fab, Nick Williams 103 TB, BBK long tube headers, Magnuson 2650, Snow Performance Water/Methanol Injection.
Did you plug your MPVI into your computer while you did it, may need to sync.
Yes, it was plugged in but said "Polling Failed". I don't know what that means. Why would it fail?
Ok after jumping through a bunch of hoops-Resyncing, taking the training, Resyncing, updating twice, getting a verification code, adding my device and doing these steps several times I finally got the license info to show on the new(old) laptop. Still when I tried to "Save As" wouldn't work. Shut it down and it asked if I wanted to save and I said Yes so it went to the "Save As" box. After that the "Save As" was available. So now I think I can use it to tune.
Wonder how long before we wont be able to tune at all?
I have a 2011 Dodge Durango Citadel 5.7. I ordered the Tomahawk Camshaft for it, and when receiving my MPVI2+ with custom N/A tuning and 2 credits when I went to read my base tune the only option popping up is my ECM there is no TCM or FSCM(which I know I don't need this option), so my question being with my vehicle is everything read just through my ECM then? I figured it is as it is showing the engine, engine diag, Trans, Trans diag, fuel sys, hvac, and speedometer readings.
