Thread: hard shifts after coming off the pedal, like if theres a trailer.
    Jan 2021
    Miami
    351
    tranny not right but working.if i pull back on throttle between shifts. there's a hard shift to next gear! what area of tuning should be adjusted to remove this issue? thanks in advance.
    By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
    Aug 2021
    Indianapolis Area
    187
    Hello Turbo2gnx,
    Could you better describe your issue? Which engine? Which transmission? Any modification? Running with standard transmission tuning?
    Dodge Boy
    (YouTube: https://www.youtube.com/channel/UCAl...jzHdK8B9m1Z2lQ)
    Jan 2021
    Miami
    351
    Quote Originally Posted by DodgeBoy_8HP View Post
    Hello Turbo2gnx,
    Dodge Boy
    greetings. 5.7 with 220/230 comp cam, LT tube headers eagle heads and Nag1 transmission with 2600stall torque converter. while driving from 1-2 and 2-3 theres a late hard shift if i let off the throttle before the shift, feels like hitting the brakes and towing a trailer and feeling the hit of a slack hitch.
    Aug 2021
    Indianapolis Area
    187
    sounds like shift pressure issue...
    But, I am not specialist on NAG1... sorry
