Results 1 to 6 of 6
Thread: Gen 3 swap question on o2 sensors grayed out ( can't edit)
    Jun 2020
    20
    Good evening fellas,
    I'm in the process of doing a swap on a Colorado. I've hooked everything up (mostly).
    I turned on the PCM and downloaded the pcm file using my hptuner software. I found the VAT
    and disabled it, not problem. When I went over to the DTCs.... most of the 02 stuff in the "SES
    enable" and "error mode" columns were grayed out. I can't seem to change it. The other stuff is
    fine. I can click on the other DTCs and check and uncheck them.
    Now the wiring harness I have... the rear O2 stuff is not incorporated or wired. Could the pcm
    detected that they were not connected and decided to gray that stuff out?
    Or is it as simple as I have not yet bought the credits to reload my edited file and doing that
    will unlock those columns? it's weird though because I can go into other sections and edit stuff.
    JUst not the o2 stuff.
    13,609
    Do the training course, then you can edit stuff. It's a well talked about topic currently.
    Jun 2020
    20
    I figured it out.
    thx for the help.
    Quote Originally Posted by Jquest View Post
    I figured it out.
    thx for the help.
    What did you do ?
    2000 ss-stock w/ls6 intake 3.42 a4
    1985 El Camino ss 327
    2002 z28 built 347 ls1 A3
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    204
    Quote Originally Posted by 2000ss View Post
    What did you do ?
    either do the training course or download an older VCM Suite
    Xstages Motorsport
    Tuning inquiries:
    ECU, TCU, CPC Online Tuning
    Whatsapp: +971503383340
    Email: [email protected]
    Insta: @xstages.motorsport
    www.xstages.com
    Dec 2019
    MS
    568
    He had to take the training course.
    Google is your friend..
    https://www.youtube.com/watch?v=4aHN0r4f4UY
