Results 1 to 2 of 2
Thread: Assign all inputs to one data overlay
    Dec 2022
    Racerender - is there a way to Assign all inputs to one data overlay without having to select the same GPS data overlay file for each parameter? I do short video clips with overlay and I'll have 30 videos with seven parameters each and I have to pick the same GPS input for all seven parameters for all video files. I just need each video and corresponding GPS file to configure with one GPS input.
    Apr 2018
    299
    This seems like an ideal scenario for a Template. Once you've setup all of the gauges and displays once, you can export the layout as a template so that all of the setup work is handled automatically: https://racerender.com/RR3/docs/TemplateCreate.html
    Once you have the template, you can select that from the initial menu. Then you should be able to import the data file and video file, and all of the displays should automatically use the same fields as the ones you originally setup in the template.
