I have a 2006 Tahoe and I want to change the injectors to 50lbs (Precision injectors ). Whats the numbers that must be intered in the Flow rate VS. KPA? Is there a formula or equation that must be used to get to right number?
You can try just multipling the IFR table by difference in injector size. So if you have let's say 30lb/hr ones, and you want to put 50lb/hr's in, you just divide 50/30, take that product and mulitiply your IFR table by that. Hope that helps.
Have a few thousand files I can share. I'm not on here often so please email me. [email protected]
not exactly...just use the spreadsheet from the stickies
Thank you Redhardsupra for the great site...![]()
