Thread: Question about HP Tuners unlocking my Ram 2017 computer
    Dec 2020
    6
    Got a 2017 Ram 1500 with the Hemi and 8 speed automatic.
    Currently we are chasing an electrical gremlin in the #3 coil/ injector possibly. Backstory is the #3 cylinder was throwing codes and missing. First look we found a damaged connector on the harness side of #3 coil connector. Repaired that problem by replacing the harness side connector. Swapped another coil- no help. We also understand a bad ECM/PCM might cause the same thing. When I get time I?m going to check for continuity between coil connector and computer. Other than finding an intermittent open or a wire grounding out- the computer would be the next place to check for a problem. We have a good scanner AND a HP Tuner and want to send in the OEM computer for unlocking.
    The next question is- does HP Tuners do any kind of operational verification prior to unlocking the computer?
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,018
    The pcm unlock will not solve your problem, and if you have a bad driver in the ecm, the unlock will have been wasted money. They do not verify operation of the ecm. In fact 99% of ecm rebuilders do not verify proper opration, just replace bad components, and (reflow solder).
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Dec 2020
    6
    So if I suspect a bad ECM what is next step?
    Mar 2021
    Pompano Beach FL
    272
    Quote Originally Posted by crewguy498 View Post
    get another PCM
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
