Results 1 to 8 of 8
Thread: Can we make traction control less aggressive?
    Jul 2021
    234
    This is for a c7 z06 manual. I have searched and haven't found much. I am looking for a way to let's say, make TC 50% less intrusive. I want to keep TC on because honestly on street tires I dont hook but curent TC kills power altogether the moment I lose traction and I would also prefer not to have to turn off TC every time I want to have some fun. I'd prefer to do this through spark rather than closing the throttle.
    May 2003
    South FL
    1,403
    You can try increasing the traction control torque value. It SHOULD make it come on softer if you increase the value. But I have never been able to confirm it actually works. Sometimes I thought it did and others I thought it didn't. Set it too like 800-1000 and see if it makes a difference. If so, fine tune the value to a more realistic number.
    [email protected]
    Owner/GM Calibrator
    Jul 2021
    234
    Is there no setting for spark cut traction vontrol
    May 2003
    South FL
    1,403
    nope
    There is a torque limit setting though. If you raise this value, maybe it will be less aggressive. It works on some cars.
    [email protected]
    Owner/GM Calibrator
    Tuning Addict
    6,892
    I've had to do that on other than stock tire setups that still wanted traction control. Traction control stock settings were causing fish bites while cruising via brakes being pulsed and raising it caused that to go away, so like Jason said, it should work for you.
    ~Greg Huggins~
    Jul 2021
    234
    Its quite high already I think it's 700 something. I'll try 1000
    May 2003
    South FL
    1,403
    Quote Originally Posted by kenand1988 View Post
    This value is mostly arbitrary once you change the airflow since calculated torque changes. Just think higher number should make it less intrusive and lower number would make it more agressive.
    [email protected]
    Owner/GM Calibrator
    Feb 2021
    38
    Good tips guys, I've messed with it a little as well. I upped mine slightly over stock, seemed to make little less intrusive but it was also hard to tell since I put subwoofer in trunk at 100 lbs gave me more traction as well.
