Lemme preface this by saying i havent even began to study the fueling part of this tuning fiasco. Started on the trans side because I saw some stuff on the diablo logs that did not look right. Getting that sorted. I have wanted to switch this car over to E85. I'm fortunate to live near a bunch of richie rich's and their turned up German and Italian turbo cars need consistent high octane fuel. Living where its never colder than 50 deg the E85 consistently tests high. I got some oem 808 red eye injectors from a guy. Supposedly 66 gal per hour at 60 psi. That all I know about them. I read my stockers flow 34 at 60 psi and the cars dead head system is regulated to 58 psi. E takes nearly an additional 40% mass so they should be just larger than i needed.
Question - Do i need to send the injectors out and get them flowed so i have data or ???? Whats the best way to do this?
Like i said i am completely ignorant with the fueling side of the tune. Never put bigger electronic injectors in anything before. If they need to be sent out where do you recommend i send them??
