Results 1 to 20 of 30
Thread: Car tuned in OL, how to turn on CL
    Tuner in Training Turbostangs90's Avatar
    Nov 2014
    36
    Long story short, I put the wrong sensors in for my 02, so tuner couldnt turn on the CL tuning....so the car was tuned for OL while cruising.
    I made changes to the tune to activate the CL, but when I datalog it says Closed Loop isnt active. I have attached the tune file. What am I missing??
    2009 CTSV Sedan CRT
    TMS 427, Modified Huron Twin Kit, BW-S369s, Greg Good CNC Brodix BR7s, Lil Jon Turbo Cam, PTC converter spec'd by Dusty Bradford, ID1700s, FORE Fuel System, built 6l90
    1990 Mustang tuned using Holley EFI
    7,969
    ECM 12462 - Closed Loop Enable Delay is still at max
    All the upstream O2 DTCs are still set to No Error
    (unrelated, but your injector data was not entered correctly, and fixing it now will require retuning - your flow rate table is flat as if it's using a boost referenced regulator, but the Offset vs Press vs IGNV is sloped as if it was still returnless)
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    476
    Also change your Dynamic airflow High RPM disable and re-enable. It is set to 200 and 100.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Nov 2014
    36
    My VE table isn?t tuned. Car was tuned using MAF. Is that going to be an issue?
    Nov 2014
    36
    Thank you for the input.
    Yes I am using a boost reference regulator.
    Nov 2004
    St. Louis, MO
    476
    Your VVE table is not stock.
    What year is your car?
    Nov 2014
    36
    Quote Originally Posted by PGA2B View Post
    Your VVE table does not look stock.
    The previous owner may have had that tuned. The car is an 09
    Nov 2004
    St. Louis, MO
    476
    Yeah, it's not stock.
    Quote Originally Posted by Turbostangs90 View Post
    Not an issue at all.
    This.
    Nov 2014
    36
    Thanks guys. I swear I thought I had changed that CL delay table back to stock....weird that it didnt stick.
    2009 CTSV Sedan CRT
    Nov 2014
    36
    Should I go and disable the SES and change the Error Mode to no MIL light for all bank 1, bank 2 sensor 1 codes? I counted 10 of them total.
    2009 CTSV Sedan CRT
    Keep the SES and change error mode to MIL on second error.
    Nov 2014
    36
    Quote Originally Posted by Mr.z0611 View Post
    Done, thank you
    2009 CTSV Sedan CRT
    Done, thank you
    You're welcome.
    7,969
    A stock file can be used to compare DTC differences for putting stuff back to stock. It won't show what the compare (stock) file's settings are but when they match the outlined box around what's different will go away.
    Nov 2014
    36
    I set the Closed loop enable delay to pretty much stock settings. I let the car warm up to 205* and the closed loop still didnt activate. What am I missing?TT.ClosedLoopEnabled.TUTD.hpt
    2009 CTSV Sedan CRT
    7,969
    Who mutilated the DTC list like that? There are lots of things turned off that shouldn't be, not just the upstream O2s (which are STILL set to No Error, btw).
    Set the B1S1/B2S1 O2 DTC back to stock, see if that gets the ECM reading actual O2 voltages. 450mV is what they read when open circuit - if they still won't read after fixing the tune file, you need to verify O2s are pinned correctly and plugged in to the right harness connectors.
    Nov 2014
    36
    I never looked at the DTC list until now. The previous owner took it to many tuners and was having hell with it. That may be the reason I got the car so cheap. The car runs extremely well, with no issues at all. I was just trying to get the CL working because of all of the crazy weather changes we have here.
    2009 CTSV Sedan CRT
    7,969
    There are even several ETC codes disabled in there, scary stuff.
